Datasheet HMC409LP4E (Analog Devices) - 8
DescriptionGaAs InGaP HBT 1 WATT POWER AMPLIFIER, 3.3 - 3.8 GHz
Pages / Page8 / 8 — HMC409LP4E. GaAs InGaP HBT 1 WATT. POWER AMPLIFIER, 3.3 - 3.8 GHz. …
HMC409LP4E. GaAs InGaP HBT 1 WATT. POWER AMPLIFIER, 3.3 - 3.8 GHz. Evaluation PCB
HMC409LP4E GaAs InGaP HBT 1 WATT POWER AMPLIFIER, 3.3 - 3.8 GHz Evaluation PCB
HMC409LP4E
v04.1217
T m s r - e w o p r & A e lin s - r ie lif p m A
List of Materials for Evaluation PCB 108355 [1]
The circuit board used in the application should item Description use rf circuit design techniques. signal lines should J1 - J2 pCB mount smA rf Connector have 50 ohm impedance while the package ground J3, J4 2 mm DC Header leads and exposed paddle should be connected C1 - C5 100 pf Capacitor, 0402 pkg. directly to the ground plane similar to that shown. C6 - C7 1000 pf Capacitor, 0603 pkg. A sufficient number of via holes should be used C8 10 pf Capacitor, 0402 pkg. to connect the top and bottom ground planes. The C9 0.5 pf Capacitor, 0603 pkg. evaluation board should be mounted to an appropri- C10 1.6 pf Capacitor, 0603 pkg. ate heat sink. The evaluation circuit board shown is C11 4.7 µf, Tantalum available from Analog Devices, upon request. l1, l2 3.9 nH inductor, 0603 pkg. l3 2.2 nH inductor, 0402 pkg. Toko r1 56 ohm resistor, 0603 pkg. U1 HmC409lp4e Amplifier pCB [2] 108353 eval Board [1] reference this number when ordering complete evaluation pCB [2] Circuit Board material: rogers 4350, er = 3.48 For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D
8
Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications EVM vs. Temperature @ 3.5 GHz OFDM 54 Mbps Signal Power Dissipation Gain, Power & Quiescent Supply Current vs. Vpd @ 3.5 GHz Noise Figure vs. Temperature Gain & Power vs. Supply Voltage Power Compression @ 3.5 GHz Output IP3 vs. Temperature Psat vs. Temperature P1dB vs. Temperature Power Down Isolation vs. Temperature Reverse Isolation vs. Temperature Output Return Loss vs. Temperature Input Return Loss vs. Temperature Gain vs. Temperature Broadband Gain & Return Loss Absolute Maximum Ratings Typical Supply, Current vs. Supply Voltage, Vcc1 = Vcc2 = Vpd Outline Drawing Package Information Application Circuit Pin Descriptions Evaluation PCB List of Materials
