Datasheet HMC454ST89, 454ST89E (Analog Devices) - 3
DescriptionInGaP HBT ½ WATT HIGH IP3 AMPLIFIER, 0.4 - 2.5 GHz
Pages / Page12 / 3 — HMC454ST89 / 454ST89E. InGaP HBT ½ WATT HIGH IP3. AMPLIFIER, 0.4 - 2.5 …
File Format / SizePDF / 629 Kb
HMC454ST89 / 454ST89E. InGaP HBT ½ WATT HIGH IP3. AMPLIFIER, 0.4 - 2.5 GHz. Output IP3 vs. Temperature @ 900 MHz
HMC454ST89 / 454ST89E InGaP HBT ½ WATT HIGH IP3 AMPLIFIER, 0.4 - 2.5 GHz Output IP3 vs Temperature @ 900 MHz
v05.0710
InGaP HBT ½ WATT HIGH IP3 AMPLIFIER, 0.4 - 2.5 GHz Output IP3 vs. Temperature @ 900 MHz Noise Figure vs. Temperature @ 900 MHz
44 15 43 14 42 13 41 12 +25 C +85 C 40 11 -40 C 39 GURE (dB) 10 9 IP3 (dBm) 38 9 SE FI 37 +25 C 8 NOI +85 C 36 -40 C 7 35 6 T 34 5 0.7 0.8 0.9 1 1.1 1.2 0.7 0.8 0.9 1 1.1 1.2 FREQUENCY (GHz) FREQUENCY (GHz) R - SM
Reverse Isolation Gain, Power & Output IP3
E
vs. Temperature @ 900 MHz vs. Supply Voltage @ 900 MHz
) W 45 0 O 40 -5 35 -10 +25 C +85 C 30 -15 -40 C 25 R & P -20 PSAT (dBm), IP3 (dBm A 20 -25 E ISOLATION (dB) 15 -30 IN 10 GAIN PSAT -35 P1dB IP3 5 -40 4.5 4.75 5 5.25 5.5 0.7 0.8 0.9 1 1.1 1.2 GAIN (dB), P1dB (dBm), Vs (V) S - L FREQUENCY (GHz) R IE
ACPR vs. Supply Voltage @ 880 MHz
IF
CDMA IS95, 9 Channels Forward
L -30 P -35 M -40 CDMA IS95 A Frequency : 880 MHz -45 Integration BW: 1.228 MHz 4.5V -50 Forward Link, 9 Channels 5.0V -55 -60 ACPR (dBc) 5.5V -65 -70 -75 Source ACPR -80 7 8 9 10 11 12 13 14 15 16 17 18 19 Channel Output Power (dBm) Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m
9 - 192
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
