Datasheet HMC920LP5E (Analog Devices) - 6
DescriptionACTIVE BIAS CONTROLLER
Pages / Page26 / 6 — HMC920LP5E. ACTIVE BIAS CONTROLLER. Absolute Maximum Ratings [1]. Outline …
HMC920LP5E. ACTIVE BIAS CONTROLLER. Absolute Maximum Ratings [1]. Outline Drawing. Package Information. 13 - 6
HMC920LP5E ACTIVE BIAS CONTROLLER Absolute Maximum Ratings [1] Outline Drawing Package Information 13 - 6
HMC920LP5E
v07.1013
Vdd1, Vdd2 to GND -0.3V to +16.5V CPGND to GND -0.3V to +0.3V VDIG to GND -0.3V to +5.5V Vdd1 to Vdd2 -0.3V to +0.3V VDIGFB, PORCAP, BGCAP, EN, Junction Temperature 125 °C -0.3V to (VDIG + 0.3V) CURALM, ALMTRIG to GND Continuous Pdiss (T = 85 °C) 10.27 Watts ALMSET, ALMC1, ALMC2, (Derate 256.67 mW/°C above 85 °C) -0.3V to (Vdd + 0.3V) REF to GND Thermal Resistance (R ) TH 3.9 °C/W VNEGFB, VGATE, VDRAIN, ISENSE (Junction to package bottom) -0.3V to (Vdd + 0.3V) to GND Storage Temperature -65 to +150 °C VNEGIN to GND -4V to (Vdd + 0.3V) Operating Temperature -40 to +85 °C ALML, ALMM, ALMH, LDOCC, -0.3V to (Vdd + 0.3V) ESD Sensitivity (HBM) Class 1C LDOFB to GND Note that there are two different voltage domains on VGATEFB, TRGOUT, VddALM, -0.3V to (VDIG + 0.3V) HMC920LP5E; a high voltage domain Vdd, and a low voltage VddCHK to GND domain VDIG. Take necessary precautions not to violate ABS MAX ratings of each subdomains. 13 ELECTROSTATIC SENSITIVE DEVICE OBSERVE HANDLING PRECAUTIONS T M
Outline Drawing
T - S N E M E G A N A R M E W NOTES: O 1. LEADFRAME MATERIAL: COPPER ALLOY 2. DIMENSIONS ARE IN INCHES [MILLIMETERS] 3. LEAD SPACING TOLERANCE IS NON-CUMULATIVE. C P 4. PAD BURR LENGTH SHALL BE 0.15mm MAXIMUM. PAD BURR HEIGHT SHALL BE 0.05mm MAXIMUM. D 5. PACKAGE WARP SHALL NOT EXCEED 0.05mm. 6. ALL GROUND LEADS AND GROUND PADDLE MUST BE SOLDERED TO PCB RF GROUND. 7. REFER TO HITTITE APPLICATION NOTE FOR SUGGESTED LAND PATTERN.
Package Information
Part Number Package Body Material Lead Finish MSL Rating Package Marking [1] HMC920LP5E RoHS-compliant Low Stress Injection Molded Plastic 100% matte Sn MSL1 [2] H920 XXXX [1] 4-Digit lot number XXXX [2] Max peak reflow temperature of 260 °C Information furnish F e o d r p by A rnic alo e g , d Devi ecleis vie s rby eli, a eve nd t d to b o p e a l cc a ur c at e o e an r d d releiars ble , p . Ho le we a ve sr, e c no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ontact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No : 9P7 h 8 o - n 2 e 5 : 7 0- 81- 3 3 3 2 4 9- 3 F 470 ax: 9 0 • Ord 7 e 8 r o - n 2 li 5 n 0 e a-t 337 ww 3 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com
13 - 6
Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptiptliec.actio o m n Support: Phone: 1-800-ANALOG-D
