Datasheet HMC713MS8, 713MS8E (Analog Devices) - 2
Description54 dB, LOGARITHMIC DETECTOR / CONTROLLER, 45 - 2700 MHz
Pages / Page10 / 2 — HMC713MS8 / 713MS8E. 54 DB, LOGARITHMIC. DETECTOR / CONTROLLER, 45 - 2700 …
File Format / SizePDF / 956 Kb
HMC713MS8 / 713MS8E. 54 DB, LOGARITHMIC. DETECTOR / CONTROLLER, 45 - 2700 MHz. Electrical Specifications, (continued)
HMC713MS8 / 713MS8E 54 DB, LOGARITHMIC DETECTOR / CONTROLLER, 45 - 2700 MHz Electrical Specifications, (continued)
HMC713MS8 / 713MS8E
v06.0412
Parameter conditions Min. typ. Max. Units
Power Down (EN) Interface
t Voltage range for Normal Mode 0.8 x Vcc V Voltage range for Powerdown Mode 0.2 x Vcc V M threshold Voltage Vcc/2 V s
Power Supply (Vcc)
- operating Voltage range 2.7 - 5.5 V supply current in Normal Mode 17 mA rs supply current in Power Down Mode 0.3 mA o
OUT Interface
t rise time cLPF= 0, No Power to -10 dBm, 10% - 90% 24 ns c Fall time cLPF= 0, -10 dBm to No Power, 90% - 10% 70 ns e 3 dB reduction in t output Video Bw 16 MHz demodulated output voltage e Voltage range closed Loop (eval Board setup) 0.2 - 1.2 V 0.1 to (Vcc D Voltage range open Loop V -0.1) r current Drive source / sink 3.5 / 0.51 mA e
OUTN Interface
w current Drive source / sink 3.6 / 0.47 mA o
OUTN Interface
P output Voltage range 0.2 - 2.1 V
RF Input
F= 50 MHz to 2.5 GHz Input Return Loss (S11) 10 dB Z0= 50Ω, see plot
VSET Interface
Input Impedance 1 MΩ Input Voltage Range eval Board 0.2 - 1.2 V Low Frequency Gain Vset to oUt 64 dB open Loop corner Frequency 11 kHz I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
2
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
