Datasheet ADL5513 (Analog Devices) - 5
Description1 MHz to 4 GHz, 80 dB Logarithmic Detector/Controller
Pages / Page25 / 5 — Data Sheet. ADL5513. Parameter. Conditions. Min. Typ. Max. Unit
RevisionA
Data Sheet ADL5513 Parameter Conditions Min Typ Max Unit
FREQUENCY = 2600 MHz Output Voltage: High Power Input PIN = −10 dBm 1.67 V Output Voltage: Low Power Input PIN = −50 dBm 0.83 V ±3.0 dB Dynamic Range 80 dB ±1.0 dB Dynamic Range 74 dB ±0.5 dB Dynamic Range 69 dB Maximum Input Level, ±1.0 dB 7 dBm Minimum Input Level, ±1.0 dB −67 dBm Deviation at TA = 25°C PIN = −10 dBm 0.33 dB PIN = −30 dBm 0.02 dB PIN = −50 dBm 0.01 dB Deviation vs. Temperature Deviation from output at TA = 25°C 25°C < TA < 85°C; PIN = −10 dBm +0.2/−0.4 dB −40°C < TA < +25°C; PIN = −10 dBm +0.05/−0.68 dB 25°C < TA < 125°C; PIN = −10 dBm +0.75/−0.05 dB 25°C < TA < 85°C; PIN = −30 dBm +0.1/−0.37 dB −40°C < TA < +25°C; PIN = −30 dBm +0.25/−0.4 dB 25°C < TA < 125°C; PIN = −30 dBm 0.8 dB 25°C < TA < 85°C; PIN = −50 dBm +0.2/−0.6 dB −40°C < TA < +25°C; PIN = −50 dBm ±0.5 dB 25°C < TA < 125°C; PIN = −50 dBm 1.13 dB Logarithmic Slope 21 mV/dB Logarithmic Intercept −89 dBm Input Impedance 0.4/0.6 kΩ/pF FREQUENCY = 3.6 GHz Output Voltage: High Power Input PIN = −10 dBm 1.74 V Output Voltage: Low Power Input PIN = −50 dBm 0.84 V ±3.0 dB Dynamic Range 76 dB ±1.0 dB Dynamic Range 62 dB ±0.5 dB Dynamic Range 58 dB Maximum Input Level, ±1.0 dB 1 dBm Minimum Input Level, ±1.0 dB −61 dBm Deviation at TA = 25°C PIN = −10 dBm 0.43 dB PIN = −30 dBm −0.05 dB PIN = −50 dBm −0.14 dB Deviation vs. Temperature Deviation from output at TA = 25°C 25°C < TA < 85°C; PIN = −10 dBm +0.32/−0.28 dB −40°C < TA < +25°C; PIN = −10 dBm +0.27/−0.54 dB 25°C < TA < 125°C; PIN = −10 dBm +0.58/−0.21 dB 25°C < TA < 85°C; PIN = −30 dBm +0.3/−0.22 dB −40°C < TA < +25°C; PIN = −30 dBm +0.38/−0.33 dB 25°C < TA < 125°C; PIN = −30 dBm +0.67/−0.05 dB 25°C < TA < 85°C; PIN = −50 dBm +0.41/−0.37 dB −40°C < TA < +25°C; PIN = −50 dBm +0.41/−0.62 dB 25°C < TA < 125°C; PIN = −50 dBm +0.8/−0.18 dB Logarithmic Slope 22.5 mV/dB Logarithmic Intercept −87 dBm Input Impedance 0.5/0.4 kΩ/pF SETPOINT INPUT Pin VSET Nominal Range Log conformance error ≤ ±1 dB, RF input = 8 dBm 2 V Log conformance error ≤ ±1 dB, RF input = −62 dBm 0.58 V Logarithmic Scale Factor 47.1 dB/ V Input Impedance 40 kΩ Rev. A | Page 5 of 25 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Information Basic Connections Input Signal Coupling Output Filtering Output Interface Setpoint Interface Description of Characterization Error Calculations Adjusting Accuracy Through Choice of Calibration Points Temperature Compensation of Output Voltage Device Calibration Power-Down Functionality Measurement Mode Setting the Output Slope in Measurement Mode Controller Mode Constant Power Operation Increasing the Dynamic Range of the ADL5513 Evaluation Board Outline Dimensions Ordering Guide
