Datasheet ADL5513 (Analog Devices) - 10
Description1 MHz to 4 GHz, 80 dB Logarithmic Detector/Controller
Pages / Page25 / 10 — ADL5513. Data Sheet. 2.4. 3.0. 2.2. 2.5. 2.0. 1.8. 1.5. 1.6. 1.0. 1.4. …
RevisionA
ADL5513. Data Sheet. 2.4. 3.0. 2.2. 2.5. 2.0. 1.8. 1.5. 1.6. 1.0. 1.4. 0.5. (V). 1.2. R (. –0.5. RRO. 0.8. –1.0. +25°C. 0.6. –1.5. –40°C. 0.4. –2.0. +85°C. 125°C. 0.2. –2.5. –3.0
ADL5513 Data Sheet 2.4 3.0 2.2 2.5 2.0 1.8 1.5 1.6 1.0 1.4 0.5 (V) 1.2 R ( –0.5 RRO 0.8 –1.0 +25°C 0.6 –1.5 –40°C 0.4 –2.0 +85°C 125°C 0.2 –2.5 –3.0
ADL5513 Data Sheet 2.4 3.0 2.4 3.0 2.2 2.5 2.2 2.5 2.0 2.0 2.0 2.0 1.8 1.5 1.8 1.5 1.6 1.0 1.6 1.0 1.4 0.5 B) B) d 1.4 0.5 d (V) (V) 1.2 0 R ( 1.2 0 R ( UT UT O O V 1.0 –0.5 RRO V 1.0 –0.5 RRO E E 0.8 –1.0 0.8 –1.0 +25°C 0.6 +25°C –1.5 0.6 –1.5 –40°C –40°C 0.4 –2.0 +85°C +85°C 0.4 –2.0 125°C 0.2 125°C –2.5 0.2 –2.5 0 –3.0 0 –3.0 –70 –60 –50 –40 –30 –20 –10 0 10
008
011
PIN (dBm) P
07514-
IN (dBm)
07514- Figure 9. VOUT and Log Conformance vs. Input Amplitude at 2140 MHz, Figure 12. VOUT and Log Conformance vs. Input Amplitude at 2140 MHz, Typical Device, VTADJ = 0.84 V Multiple Devices, VTADJ = 0.84 V
2.4 3.0 2.4 3.0 2.2 2.5 2.2 2.5 2.0 2.0 2.0 2.0 1.8 1.5 1.8 1.5 1.6 1.0 1.6 1.0 1.4 0.5 B) B) d 1.4 0.5 d (V) (V) 1.2 0 R ( 1.2 0 R ( UT UT O O V 1.0 –0.5 RRO V 1.0 –0.5 RRO E E 0.8 –1.0 0.8 –1.0 +25°C 0.6 +25°C –1.5 0.6 –1.5 –40°C –40°C 0.4 –2.0 0.4 +85°C –2.0 +85°C 125°C 0.2 125°C –2.5 0.2 –2.5 0 –3.0 0 –3.0 –70 –60 –50 –40 –30 –20 –10 0 10
009
012
PIN (dBm) P
07514-
IN (dBm)
07514- Figure 10. VOUT and Log Conformance vs. Input Amplitude at 2600 MHz, Figure 13. VOUT and Log Conformance vs. Input Amplitude at 2600 MHz, Typical Device, VTADJ = 0.83 V Multiple Devices, VTADJ = 0.83 V
013
016
PIN (dBm) P
07514-
IN (dBm)
07514- Figure 14. V Figure 11. V OUT and Log Conformance vs. Input Amplitude at 3600 MHz, OUT and Log Conformance vs. Input Amplitude at 3600 MHz, Multiple Devices, V Typical Device, V TADJ = 0.90 V TADJ = 0.90 V Rev. A | Page 10 of 25 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Information Basic Connections Input Signal Coupling Output Filtering Output Interface Setpoint Interface Description of Characterization Error Calculations Adjusting Accuracy Through Choice of Calibration Points Temperature Compensation of Output Voltage Device Calibration Power-Down Functionality Measurement Mode Setting the Output Slope in Measurement Mode Controller Mode Constant Power Operation Increasing the Dynamic Range of the ADL5513 Evaluation Board Outline Dimensions Ordering Guide
