Datasheet AD8317 (Analog Devices) - 8
Description1 MHz to 10 GHz, 55 dB Log Detector/Controller
Pages / Page19 / 8 — AD8317. Data Sheet. 2.00. 2.0. 1.75. 1.5. 1.50. 1.0. 1.25. 0.5. T 1.00. R …
RevisionD
AD8317. Data Sheet. 2.00. 2.0. 1.75. 1.5. 1.50. 1.0. 1.25. 0.5. T 1.00. R O. RO R. 0.75. –0.5. 0.50. –1.0. 0.25. –1.5. –2.0
AD8317 Data Sheet 2.00 2.0 1.75 1.5 1.50 1.0 1.25 0.5 T 1.00 R O RO R 0.75 –0.5 0.50 –1.0 0.25 –1.5 –2.0
AD8317 Data Sheet 2.00 2.0 2.00 2.0 1.75 1.5 1.75 1.5 1.50 1.0 1.50 1.0 1.25 0.5 1.25 0.5 ) B) ) B) V V ( (d (d ( T 1.00 0 R T 1.00 0 R O OU OU V RO R V RR 0.75 E –0.5 0.75 –0.5 E 0.50 –1.0 0.50 –1.0 0.25 –1.5 0.25 –1.5 0 –2.0 0 –2.0
2 09
–60 –55 –50 –45 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10
0
01 1- 1- 54 54
P P IN (dBm)
05
IN (dBm)
05 Figure 9. VOUT and Log Conformance vs. Input Amplitude at 900 MHz, Figure 12. VOUT and Log Conformance vs. Input Amplitude at 3.6 GHz, Multiple Devices, RTADJ = 18 kΩ Multiple Devices, RTADJ = 8 kΩ
2.00 2.0 2.00 2.0 1.75 1.5 1.75 1.5 1.50 1.0 1.50 1.0 1.25 0.5 1.25 0.5 ) B) B) V ) ( (d V (d T ( 1.00 0 R T 1.00 0 R OUV OU RO RRO V R 0.75 E –0.5 0.75 E –0.5 0.50 –1.0 0.50 –1.0 0.25 –1.5 0.25 –1.5 0 –2.0 0 –2.0
10 0
13 0 1-
1- 54
P
54
IN (dBm)
05
PIN (dBm)
05 Figure 10. VOUT and Log Conformance vs. Input Amplitude at 1.9 GHz, Figure 13. VOUT and Log Conformance vs. Input Amplitude at 5.8 GHz, Multiple Devices, RTADJ = 8 kΩ Multiple Devices, RTADJ = 500 Ω
2.00 2.0 2.00 2.0 1.75 1.5 1.75 1.5 1.50 1.0 1.50 1.0 1.25 0.5 1.25 0.5 ) B) B) V ) ( (d V (d T ( 1.00 0 R T 1.00 0 R OUV RO OU R V RRO 0.75 E –0.5 0.75 E –0.5 0.50 –1.0 0.50 –1.0 0.25 –1.5 0.25 –1.5 0 –2.0 0 –2.0 –60 –55 –50 –45 –40 –35 –30 –25 –20 –15 –10 –5 0 5
14 -011 0
41 1-
P
54 055
IN (dBm) PIN (dBm)
05 Figure 11. VOUT and Log Conformance vs. Input Amplitude at 2.2 GHz, Figure 14. VOUT and Log Conformance vs. Input Amplitude at 8.0 GHz, Multiple Devices, RTADJ = 8 kΩ Multiple Devices, RTADJ = Open, Error Calculated from PIN = −34 dBm to PIN = −16 dBm Rev. D | Page 8 of 19 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION USING THE AD8317 BASIC CONNECTIONS INPUT SIGNAL COUPLING OUTPUT INTERFACE SETPOINT INTERFACE TEMPERATURE COMPENSATION OF OUTPUT VOLTAGE MEASUREMENT MODE SETTING THE OUTPUT SLOPE IN MEASUREMENT MODE CONTROLLER MODE OUTPUT FILTERING OPERATION BEYOND 8 GHz EVALUATION BOARD DIE INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
