19 /9 — Data Sheet. AD8317. 10000. j0.5. –60dBm. / H V. j0.2. n ( Y 1000. IT S. …
Revision
D
PDF / 1.2 Mb
Data Sheet. AD8317. 10000. j0.5. –60dBm. / H V. j0.2. n ( Y 1000. IT S. –40dBm. RF OFF. 0.2. 0.5. L A R. –20dBm. –10dBm. 100MHz. E 100. –j0.2. 900MHz. OIS. 0dBm
Data SheetAD8317j110000j0.5j2z)–60dBm/ H Vj0.2n ( Y 1000IT S–40dBmNRF OFFE0D0.20.512L A R–20dBmT–10dBmC100MHzE 100P–j0.2S900MHzEOIS0dBm1900MHzN 018 1- 8000MHz2200MHz–j0.5–j2 54 05 103600MHz1k10k100k1M10MSTART FREQUENCY = 0.05GHz–j1FREQUENCY (Hz)STOP FREQUENCY = 10GHz 015 5800MHz10000MHz 05541- Figure 15. Input Impedance vs. Frequency; No Termination Resistor on INHI Figure 18. Noise Spectral Density of Output; CLPF = Open (Impedance De-Embedded to Input Pins), Z0 = 50 Ω 10000Δ : 1.86V@ : 1.69Vz) / H V n ( Y 1000IT S N E D L A R T C E 100P3S E S OI N 7 019 1-01 1- 54 54 05 4 05 10Ch3 500mV Ch4 200mVM4.00µsA Ch3 620mV1k10k100k1M10MT 12.7560µsFREQUENCY (Hz) Figure 16. Power-On/Power-Off Response Time; VPOS = 3.0 V; Figure 19. Noise Spectral Density of Output Buffer (from CLPF to VOUT); Input AC-Coupling Capacitors = 10 pF; CLPF = Open CLPF = 0.1 μF 2.002.01.751.51.501.0CH1 RISE10.44ns1.250.5))BCH1 FALLV ((d6.113nsT 1.00R0OUVRRO0.75E–0.50.50–1.0 16 0 3.3V–1.5 1- 0.253.0V 554 0 3.6VCH1 200mVM20.0nsA CH1 1.40V0–2.0T 943.600ns 020 –65–55–45–35–25–15–5515P 541- IN (dBm) 05 Figure 17. V Figure 20. Output Voltage Stability vs. Supply Voltage at 1.9 GHz OUT Pulse Response Time; Pulsed RF Input 0.1 GHz, −10 dBm; C When V LPF = Open; RLOAD = 150 Ω POS Varies by 10% Rev. D | Page 9 of 19 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION USING THE AD8317 BASIC CONNECTIONS INPUT SIGNAL COUPLING OUTPUT INTERFACE SETPOINT INTERFACE TEMPERATURE COMPENSATION OF OUTPUT VOLTAGE MEASUREMENT MODE SETTING THE OUTPUT SLOPE IN MEASUREMENT MODE CONTROLLER MODE OUTPUT FILTERING OPERATION BEYOND 8 GHz EVALUATION BOARD DIE INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
