Datasheet AD626 (Analog Devices) - 4
DescriptionLow Cost, Single-Supply Differential Amplifier
Pages / Page12 / 4 — AD626. ABSOLUTE MAXIMUM RATINGS1. ORDERING GUIDE. Temperature Package …
RevisionD
File Format / SizePDF / 204 Kb
AD626. ABSOLUTE MAXIMUM RATINGS1. ORDERING GUIDE. Temperature Package Package Model Range Description Option
AD626 ABSOLUTE MAXIMUM RATINGS1 ORDERING GUIDE Temperature Package Package Model Range Description Option
NOTES 1 Supply Voltage . +36 V Stresses above those listed under Absolute Max i mum Ratings may cause per ma nent damage to the device. This is a stress rating only; functional operation of the device Internal Power Dissipation2 at these or any other conditions above those indicated in the operational section of Peak Input Voltage . +60 V this specifi cation is not implied. Exposure to ab so lute maximum rating con di tions Maximum Reversed Supply Voltage Limit . –34 V for extended periods may affect device re li abil i ty. Output Short Circuit Duration . Indefi nite 2 8-Lead Plastic Package: ␪JA = 100°C/W; ␪JC = 50°C/W. Storage Temperature Range (N, R) . –65°C to +125°C 8-Lead SOIC Package: ␪JA = 155°C/W; ␪JC = 40°C/W. Operating Temperature Range AD626A/AD626B . – 40°C to +85°C Lead Temperature Range (Soldering 60 sec) . +300°C
AD626AN – 40°C to +85°C Plastic DIP N-8 AD626AR –40°C to +85°C Small Outline IC R-8 AD626BN –40°C to +85°C Plastic DIP N-8 AD626AR-REEL –40°C to +85°C 13" Tape and Reel AD626AR-REEL7 –40°C to +85°C 7" Tape and Reel
METALLIZATION PHOTOGRAPH
Dimensions shown in inches and (mm).
CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily ac cu mu late on the human body and test equipment and can discharge without detection. Although the AD626 features proprietary ESD pro tec tion circuitry, permanent damage may occur on devices subjected to high energy electrostatic discharges. Therefore, proper ESD pre cau tions are rec om mend ed to avoid per for mance deg ra da tion or loss of functionality. –4– REV. D Document Outline FEATURES APPLICATIONS PRODUCT DESCRIPTION CONECTION DIAGRAM SPECIFICATIONS SINGLE SUPPLY DUAL SUPPLY ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE Typical Performance Characteristics THEORY OF OPERATION ADJUSTING THE GAIN OF THE AD626 SINGLE-POLE LOW-PASS FILTERING CURRENT SENSOR INTERFACE BRIDGE APPLICATION OUTLINE DIMENSIONS Revision History
