Typical Performance Characteristics–AD626256V5S = ⴞ 5VGAIN = 10, 100204 ⴞ V15CM FOR SINGLEAND DUAL SUPPLIES321015 ⴞ VCM FOR DUALINPUT COMMON-MODE RANGE – VPOSITIVE OUTPUT VOLTAGE – VSUPPLIES ONLY00–11234510100 10k1kSUPPLY VOLTAGE – ⴞ VLOAD RESISTANCE – ⍀ TPC 1. Input Common-Mode Range vs. Supply TPC 4. Positive Output Voltage Swing vs. Resistive Load 5–6TA = 25 ⴗ C–54SINGLE AND–4DUAL SUPPLY3–3GAIN = 10–22GAIN = 100DUAL SUPPLY–1ONLY1NEGATIVE OUTPUT VOLTAGE – V0POSITIVE OUTPUT VOLTAGE SWING – V010123451001k 100k10kSUPPLY VOLTAGE – VLOAD RESISTANCE – ⍀ TPC 2. Positive Output Voltage Swing vs. Supply Voltage TPC 5. Negative Output Voltage Swing vs. Resistive Load –530TA = 25 ⴗ CV–4 20–3DUAL SUPPLY ONLY–210–1CHANGE IN OFFSET VOLTAGE –NEGATIVE OUTPUT VOLTAGE SWING – V00123450SUPPLY VOLTAGE – V012345WARM-UP TIME – Minutes TPC 3. Negative Output Voltage Swing vs. Supply Voltage TPC 6. Change in Input Offset Voltage vs. Warm-Up Time REV. D –5– Document Outline FEATURES APPLICATIONS PRODUCT DESCRIPTION CONECTION DIAGRAM SPECIFICATIONS SINGLE SUPPLY DUAL SUPPLY ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE Typical Performance Characteristics THEORY OF OPERATION ADJUSTING THE GAIN OF THE AD626 SINGLE-POLE LOW-PASS FILTERING CURRENT SENSOR INTERFACE BRIDGE APPLICATION OUTLINE DIMENSIONS Revision History
