Datasheet AD626 (Analog Devices) - 9
DescriptionLow Cost, Single-Supply Differential Amplifier
Pages / Page12 / 9 — AD626. 100. ERROR OUT. 10k. +VS. INPUT. 20V p–p. THEORY OF OPERATION. …
RevisionD
File Format / SizePDF / 204 Kb
AD626. 100. ERROR OUT. 10k. +VS. INPUT. 20V p–p. THEORY OF OPERATION. FILTER. 5pF. 200k. R12. +IN. 100k. –IN. OUT. R17. 95k. 41k. R15. 4.2k. R11. R10. R14. R13. 500. 555
AD626 100 ERROR OUT 10k +VS INPUT 20V p–p THEORY OF OPERATION FILTER 5pF 200k R12 +IN 100k –IN OUT R17 95k 41k R15 4.2k R11 R10 R14 R13 500 555
AD626 100 100 90 90 10 10 0% 0%
TPC 25. Settling Time. VS = +5 V, G = 10 TPC 26. Settling Time. VS = +5 V, G = 100 Figure 4 shows the main elements of the AD626. The signal in puts
ERROR OUT
at Pins 1 and 8 are fi rst applied to dual resistive at ten u a tors R1
10k
10k
⍀ through R4 whose purpose is to reduce the peak com mon-mode
2k
⍀ voltage at the input to the preamplifi er—a feed back stage based
+VS
on the very low drift op amp A1. This allows the dif feren tial
10k
⍀ input voltage to be accurately amplifi ed in the pres ence of large
INPUT 20V p–p
common-mode volt ag es six times greater than that which can be
1k
AD626
tol er at ed by the actual input to A1. As a re sult, the in put CMR ex tends to six times the quantity (VS – 1 V). The over all common - mode error is min i mized by precise laser-trimming of R3 and R4,
–V
thus giving the AD626 a common-mode re jec tion ra tio (CMRR)
S
of at least 10,000:1 (80 dB). Figure 3. Settling Time Test Circuit To minimize the effect of spurious RF signals at the inputs due to rectifi cation at the input to A1, small fi lter capacitors C1 and C2
THEORY OF OPERATION
are included. The AD626 is a differential amplifi er con sist ing of a precision bal anced attenuator, a very low drift preamplifi er (A1), and an The output of A1 is connected to the in put of A2 via a 100 k⍀ out put buffer amplifi er (A2). It has been designed so that small (R12) resistor to facilitate the low-pass fi ltering of the sig nal of differential signals can be accurately am pli fi ed and fi ltered in the in ter est (see Low-Pass Filtering section). presence of large common -mode voltages (VCM), without the use The 200 k⍀ input impedance of the AD626 requires that the source of any other active components. re sis tance driving this amplifi er be low in val ue (<1 k⍀)—this is
+VS FILTER C1 AD626 5pF R1 200k
R12 +IN 100k
A1 –IN A2 OUT R2 C2 200k
5pF R17 R3 R4 95k
41k
41k
R15 R9 10k
10k
R5 4.2k
R11 R6 R7 R8 R10 R14 R13 10k
500
500
10k
10k
555
10k
GND GAIN = 100 –VS
Figure 4. Simplifi ed Schematic REV. D –9– Document Outline FEATURES APPLICATIONS PRODUCT DESCRIPTION CONECTION DIAGRAM SPECIFICATIONS SINGLE SUPPLY DUAL SUPPLY ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE Typical Performance Characteristics THEORY OF OPERATION ADJUSTING THE GAIN OF THE AD626 SINGLE-POLE LOW-PASS FILTERING CURRENT SENSOR INTERFACE BRIDGE APPLICATION OUTLINE DIMENSIONS Revision History
