link to page 7 link to page 7 link to page 7 AD628ABSOLUTE MAXIMUM RATINGS Table 3. Stresses above those listed under Absolute Maximum Ratings Parameter Rating may cause permanent damage to the device. This is a stress Supply Voltage ±18 V rating only; functional operation of the device at these or any Internal Power Dissipation See Figure 3 other conditions above those indicated in the operational Input Voltage (Common Mode) ±120 V1 section of this specification is not implied. Exposure to absolute Differential Input Voltage ±120 V1 maximum rating conditions for extended periods may affect Output Short-Circuit Duration Indefinite device reliability. Storage Temperature Range −65°C to +125°C Operating Temperature Range –40°C to +85°C THERMAL CHARACTERISTICS Lead Temperature (Soldering, 10 sec) 300°C 1.6TJ = 150°C 1 When using ±12 V supplies or higher, see the Input Voltage Range section. 1.4)1.2W ( N8-LEAD MSOP PACKAGEO1.0TI A IP S0.88-LEAD SOIC PACKAGESR DI0.6E W O P0.40.2MSOP θJA (JEDEC; 4-LAYER BOARD) = 132.54°C/WSOIC θJA (JEDEC; 4-LAYER BOARD) = 154°C/W0–60–40–20020406080100 0302- AMBIENT TEMPERATURE (°C) 99 02 Figure 3. Maximum Power Dissipation vs. Temperature ESD CAUTION Rev. G | Page 7 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION APPLICATIONS INFORMATION GAIN ADJUSTMENT INPUT VOLTAGE RANGE VOLTAGE LEVEL CONVERSION CURRENT LOOP RECEIVER MONITORING BATTERY VOLTAGES FILTER CAPACITOR VALUES KELVIN CONNECTION OUTLINE DIMENSIONS ORDERING GUIDE
