link to page 52 link to page 53 link to page 53 link to page 53 link to page 54 link to page 54 link to page 55 link to page 55 link to page 56 link to page 56 link to page 57 link to page 57 link to page 58 link to page 59 link to page 59 link to page 60 link to page 61 link to page 61 link to page 63 link to page 64 link to page 64 link to page 64 link to page 65 link to page 65 link to page 68 link to page 68 link to page 70 link to page 71 link to page 73 link to page 76 link to page 76 link to page 77 link to page 80 link to page 82 link to page 82 link to page 82 link to page 84 link to page 84 link to page 85 link to page 86 link to page 86 link to page 86 link to page 87 link to page 87 link to page 90 link to page 91 link to page 92 link to page 93 link to page 93 link to page 95 link to page 95 link to page 96 link to page 97 link to page 104 link to page 108 link to page 108 link to page 109 link to page 112 link to page 113 link to page 117 link to page 118 link to page 118 LTC7132 TABLE OF CONTENTS Open-Drain Pins ...52 Input Current and Limits ..82 Phase-Locked Loop and Frequency Synchronization . Temperature ..82 53 External Temperature Calibration..82 Minimum On-Time Considerations..53 Timing ..84 External Temperature Sense ...54 Timing—On Sequence/Ramp ...84 Input Current Sense Amplifier ...54 Timing—Off Sequence/Ramp ..85 External Resistor Configuration Pins (RCONFIG) ..55 Precondition for Restart ...86 Voltage Selection ..55 Fault Response ...86 Frequency Selection ...56 Fault Responses Al Faults ..86 Phase Selection ..56 Fault Responses Input Voltage ...87 Address Selection Using RCONFIG ...57 Fault Responses Output Voltage ...87 Efficiency Considerations ...57 Fault Responses Output Current ...90 Thermal Considerations ...58 Fault Responses IC Temperature ..91 Programmable Loop Compensation ...59 Fault Responses External Temperature ...92 Checking Transient Response ...59 Fault Sharing ...93 PolyPhase Configuration ..60 Fault Sharing Propagation ..93 PC Board Layout Checklist ...61 Fault Sharing Response ..95 PC Board Layout Debugging ...61 Scratchpad ...95 Design Example ..63 Identification ...96 Additional Design Checks ...64 Fault Warning and Status ..97 Connecting the USB to I2C/SMBus/PMBus Control er Telemetry .. 104 to the LTC7132 in System ...64 NVM Memory Commands .. 108 LTpowerPlay: An Interactive GUI for Digital Power .65 Store/Restore ... 108 PMBus Communication and Command Processing 65 Fault Logging .. 109 PMBus Command Details ...68 Block Memory Write/Read.. 112 Addressing and Write Protect ...68 Typical Applications .. 113 General Configuration Commands ..70 Package Description ... 117 On/Off/Margin ..71 Typical Application ... 118 PWM Configuration ..73 Related Parts .. 118 Voltage ..76 Input Voltage and Limits ...76 Output Voltage and Limits ..77 Output Current and Limits ..80 Rev 0 For more information www.analog.com 3 Document Outline Features Applications Typical Application Description Table of Contents Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Overview Main Control Loop EEPROM Power-Up and Initialization Soft-Start Time-Based Sequencing Voltage-Based Sequencing Shutdown Light-Load Current Operation Switching Frequency and Phase PWM Loop Compensation Output Voltage Sensing INTVCC/EXTVCC Power Output Current Sensing and Sub-Milliohm DCR Current Sensing Input Current Sensing PolyPhase Load Sharing External/Internal Temperature Sense RCONFIG (Resistor Configuration) Pins Fault Detection and Handling Status Registers and ALERT Masking Mapping Faults to FAULT Pins Power Good Pins CRC Protection Serial Interface Communication Protection Device Addressing Responses to VOUT and IIN/IOUT Faults Output Overvoltage Fault Response Output Undervoltage Response Peak Output Overcurrent Fault Response Responses to Timing Faults Responses to VIN OV Faults Responses to OT/UT Faults Internal Overtemperature Fault Response External Overtemperature and Undertemperature Fault Response Responses to Input Overcurrent and Output Undercurrent Faults Responses to External Faults Fault Logging Bus Timeout Protection Similarity Between PMBus, SMBus and I2C 2-Wire Interface PMBus Serial Digital Interface PMBus Command Summary PMBus Commands *Data Format Applications Information Current Limit Programming ISENSE0± and ISENSE1± Pins Inductor DCR Sensing Inductor Value Calculation Inductor Core Selection Low Value Resistor Current Sensing Slope Compensation and Inductor Peak Current Variable Delay Time, Soft-Start and Output Voltage Ramping Digital Servo Mode Soft Off (Sequenced Off) INTVCC/EXTVCC Power Topside MOSFET Driver Supply (CB, DB) Undervoltage Lockout CIN and COUT Selection Fault INDICATION Open-Drain Pins Phase-Locked Loop and Frequency Synchronization Minimum On-Time Considerations External Temperature Sense Input Current Sense Amplifier External Resistor Configuration Pins (RCONFIG) Voltage Selection Frequency Selection Phase Selection Address Selection Using RCONFIG Efficiency Considerations Thermal Considerations Programmable Loop Compensation Checking Transient Response PolyPhase Configuration PC Board Layout Checklist PC Board Layout Debugging Design Example Additional Design Checks Connecting the USB to I2C/SMBus/PMBus Controller to the LTC7132 in System LTpowerPlay: An Interactive GUI for Digital Power PMBus Communication and Command Processing PMBus Command Details Addressing and Write Protect General Configuration Commands On/Off/Margin PWM Configuration Voltage Input Voltage and Limits Output Voltage and Limits Output Current and Limits Input Current and Limits Temperature External Temperature Calibration Timing Timing—On Sequence/Ramp Timing—Off Sequence/Ramp Precondition for Restart Fault Response Fault Responses All Faults Fault Responses Input Voltage Fault Responses Output Voltage Fault Responses Output Current Fault Responses IC Temperature Fault Responses External Temperature Fault Sharing Fault Sharing Propagation Fault Sharing Response Scratchpad Identification Fault Warning and Status Telemetry NVM Memory Commands Store/Restore Fault Logging Block Memory Write/Read Typical Applications Package Description Typical Application Related Parts
