Datasheet STD30NF06L (STMicroelectronics) - 2
DescriptionN-Channel 60V - 0.022Ω - 35A DPAK/IPAK STripFET Power MOSFET
Pages / Page10 / 2 — STD30NF06L. THERMAL DATA. AVALANCHE CHARACTERISTICS. Symbol. Parameter. …
File Format / SizePDF / 476 Kb
STD30NF06L. THERMAL DATA. AVALANCHE CHARACTERISTICS. Symbol. Parameter. Max Value. Unit. ELECTRICAL CHARACTERISTICS. Test Conditions. Min
STD30NF06L THERMAL DATA AVALANCHE CHARACTERISTICS Symbol Parameter Max Value Unit ELECTRICAL CHARACTERISTICS Test Conditions Min
Rthj-case Thermal Resistance Junction-case Max 2.14 °C/W Rthj-amb Thermal Resistance Junction-ambient Max 100 °C/W Tl Maximum Lead Temperature For Soldering Purpose 275 °C
IAR Avalanche Current, Repetitive or Not-Repetitive 35 A (pulse width limited by Tj max) EAS Single Pulse Avalanche Energy 150 mJ (starting Tj = 25 °C, ID = IAR, VDD = 50 V)
(TCASE = 25 °C UNLESS OTHERWISE SPECIFIED) OFF
Symbol Parameter Test Conditions Min. Typ. Max. Unit
V(BR)DSS Drain-source ID = 250 µA, VGS = 0 60 V Breakdown Voltage IDSS Zero Gate Voltage VDS = Max Rating 1 µA Drain Current (VGS = 0) VDS = Max Rating, TC = 125 °C 10 µA IGSS Gate-body Leakage VGS = ± 20 V ±100 nA Current (VDS = 0) ON (1)
VGS(th) Gate Threshold Voltage VDS = VGS, ID = 250 µA 1 1.7 2.5 V RDS(on) Static Drain-source On VGS = 5 V, ID = 18 A 0.025 0.03 Ω Resistance VGS = 10 V, ID = 18 A 0.022 0.028 Ω DYNAMIC
gfs (1) Forward Transconductance VDS > =15 V , ID =15 A 25 S Ciss Input Capacitance VDS = 25 V, f = 1 MHz, VGS = 0 1600 pF Coss Output Capacitance 215 pF Crss Reverse Transfer 60 pF Capacitance 2/10
