Datasheet TPS62902 (Texas Instruments) - 7
ManufacturerTexas Instruments
Description3-V to 17-V, 2-A, high-efficiency and low IQ buck converter 1.5-mm × 2-mm QFN package
Pages / Page50 / 7 — TPS62902. www.ti.com. 6.6 Typical Characteristics. Current (uA). Input. …
File Format / SizePDF / 7.3 Mb
TPS62902. www.ti.com. 6.6 Typical Characteristics. Current (uA). Input. VIN (V). Temperature (C)
TPS62902 www.ti.com 6.6 Typical Characteristics Current (uA) Input VIN (V) Temperature (C)
TPS62902 www.ti.com
SLVSFM1 – MARCH 2021
10 100 -40C 17V 9 0C 90 12V 25C 6V 125C 3V 8 150C 80 7 70 6 60 5 50
Current (uA) Current (uA)
4 40
Input Input
3 30 2 20 1 10 0 0 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 -40 -20 0 20 40 60 80 100 120 140 160
VIN (V) Temperature (C) Figure 6-1. Typical Quiescent Current vs VIN Figure 6-2. Maximum Quiescent Current vs Temperature
1.8 0.85 -40C -40C -25C 25C 1.6 0C 85C 0.8 25C 125C 85C 125C 1.4 150C
0.75 150C
1.2 0.7 1 0.65
Current (uA)
0.8 0.6
Input
0.6 0.55 0.4
Vout Accuracy VFEB (±
0.2 0.5 0 0.45 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
VIN (V) VIN (V) Figure 6-3. Typical Shutdown Current Figure 6-4. Output Voltage Accuracy - VFEB Selected
Copyright © 2021 Texas Instruments Incorporated Submit Document Feedback 7 Product Folder Links: TPS62902 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics 6.6 Typical Characteristics 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 Mode Selection and Device Configuration MODE/S-CONF 7.3.2 Adjustable VO Operation (External Voltage Divider) 7.3.3 Setable VO Operation (VSET and Internal Voltage Divider) 7.3.4 Soft Start / Tracking (SS/TR) 7.3.5 Smart Enable with Precise Threshold 7.3.6 Power Good (PG) 7.3.7 Undervoltage Lockout (UVLO) 7.3.8 Current Limit And Short Circuit Protection 7.3.9 Thermal Shutdown 7.4 Device Functional Modes 7.4.1 Pulse Width Modulation (PWM) Operation 7.4.2 AEE (Automatic Efficiency Enhancement) 7.4.3 Power Save Mode Operation (Auto PFM/PWM) 7.4.4 100% Duty-Cycle Operation 7.4.5 Output Discharge Function 7.4.6 Starting into a Pre-Biased Load 8 Application and Implementation 8.1 Application Information 8.2 Typical Application with Adjustable Output Voltage 8.2.1 Design Requirements 8.2.2 Detailed Design Procedure 8.2.2.1 Custom Design With WEBENCH® Tools 8.2.2.2 Programming the Output Voltage 8.2.2.3 External Component Selection 8.2.2.4 Inductor Selection 8.2.2.5 Capacitor Selection 8.2.2.5.1 Output Capacitor 8.2.2.5.2 Input Capacitor 8.2.2.5.3 Soft-Start Capacitor 8.2.2.6 Tracking Function 8.2.2.7 Output Filter and Loop Stability 8.2.3 Application Curves 8.2.4 Typical Application with Setable VO using VSET 8.2.4.1 Design Requirements 8.2.4.2 Detailed Design Procedure 8.2.4.3 Application Curves 8.3 System Examples 8.3.1 LED Power Supply 8.3.2 Powering Multiple Loads 8.3.3 Voltage Tracking 8.3.4 Precise Soft-Start Timing 9 Power Supply Recommendations 10 Layout 10.1 Layout Guidelines 10.2 Layout Example 10.2.1 Thermal Considerations 11 Device and Documentation Support 11.1 Device Support 11.1.1 Development Support 11.1.1.1 Custom Design With WEBENCH® Tools 11.2 Receiving Notification of Documentation Updates 11.3 Support Resources 11.4 Trademarks 11.5 Electrostatic Discharge Caution 11.6 Glossary 12 Mechanical, Packaging, and Orderable Information
