19-1819; Rev 2; 10/04 Low-Cost, Remote SOT Temperature SwitchesMAX6511/MAX6512/MAX6513General DescriptionFeatures The MAX6511/MAX6512/MAX6513 are fully integrated, ♦ Continuously Measure External Junction remote temperature switches that use an external P-N Temperature junction (typically a diode-connected transistor) as the ♦ sensing element to measure the remote temperature. Factory-Programmed Temperature Threshold from These devices assert a logic signal when the tempera- +45°C to +125°C in 10°C Increments ture crosses a factory-programmed threshold. Available ♦ Insensitive to Series Parasitic Resistance trip thresholds are from +45°C to +125°C in 10°C incre- ♦ Active-Low CMOS Output (MAX6511) or Open-Drain ments. Accuracy is within ±3°C (TA = -5°C to +55°C) or Output for Overtemperature Alarm (MAX6512) or ±5°C (TA = -40°C to +85°C). Hysteresis is pin selec- Active-High Output (MAX6513) for Direct Fan Control table to 5°C or 10°C. ♦ <100ms Response Time The MAX6511 has an active-low CMOS output and the MAX6513 has an active-high CMOS output. The ♦ Accuracy MAX6512 has an open-drain output. The output is ±3°C (TREMOTE = +45°C to +125°C, TA = -5°C to +55°C) asserted when the temperature exceeds the threshold ±5°C (TREMOTE = +45°C to +125°C, TA = -40°C to +85°C) value. The active-low open-drain output is intended to ♦ Pin-Selectable 5°C or 10°C Hysteresis interface with a microprocessor (µP) reset or interrupt input. The active-high CMOS output can directly drive a ♦ 400µA Average Current Consumption power FET to control a cooling fan. ♦ +3.0V to +5.5V Supply Range The MAX6511/MAX6512/MAX6513 operate from a ♦ 6-Pin SOT23 Package +3.0V to +5.5V supply and typically consume 400µA of ♦ 6-Pin TDFN Package (Lead Free) supply current. They are available in the small 6-pin SOT23. The MAX6513 is also available in a 6-pin lead- free TDFN package. ________________________ApplicationsOrdering Information CPU Temperature Monitoring in High-Speed PIN- Computers PART*TEMP RANGEOUTPUTPACKAGE Multichip Modules CMOS M AX6 511 UT_ _ _ -T -40°C to +85°C 6 SOT23-6 Battery Packs (active low) Temperature Control M AX6 512 UT_ _ _ -T -40°C to +85°C 6 SOT23-6 Open-drain Temperature Alarms -40°C to +85°C 6 TDFN CMOS M AX6 513 _T_ _ _ -T Fan Control -40°C to +85°C 6 SOT23-6 (active high) *These parts are offered in nine standard temperature versions with a minimum order of 2500 pieces. To complete the suffix information, select an available trip point in degrees centigrade Pin Configuration from the device marking codes table. For example, the MAX6511UT065-T describes a MAX6511 in a 6-pin SOT23 TOP VIEW package with a +65°C threshold. VDD 1 6 DXP MAX6511 GND 2 5 DXN MAX6512 MAX6513 HYST 3 4 TOVER (TOVER) ( ) ARE FOR MAX6513 SOT23 ONLY. Typical Operating Circuit appears at end of data sheet.________________________________________________________________ Maxim Integrated Products1For pricing, delivery, and ordering information, please contact Maxim/Dallas Direct! at 1-888-629-4642, or visit Maxim’s website at www.maxim-ic.com.
