Datasheet B220/A, B260/A (Diodes)
Manufacturer | Diodes |
Description | 2.0A SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER |
Pages / Page | 5 / 1 — Green. B220/A - B260/A. 2.0A SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER. … |
File Format / Size | PDF / 396 Kb |
Green. B220/A - B260/A. 2.0A SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER. Features. Mechanical Data
Green B220/A - B260/A 2.0A SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER Features Mechanical Data
Guard Ring Die Construction for Transient Protection Case: SMA/SMB Ideally Suited for Automated Assembly Case Material: Molded Plastic. UL Flammability Classification Low Power-Loss, High Efficiency Rating 94V-0 Surge Overload Rating to 50A Peak Moisture Sensitivity: Level 1 per J-STD-020 For Use in Low-Voltage, High-Frequency Inverters, Terminals: Lead Free Plating (Matte Tin Finish). Solderable per Free-Wheeling, and Polarity Protection Application MIL-STD-202, Method 208 High-Temperature Soldering: +260°C/10 Second at Terminal Polarity: Cathode Band or Cathode Notch
Lead-Free Finish; RoHS Compliant (Notes 1 & 2)
Weight: SMA 0.064 grams (Approximate)
Halogen and Antimony Free. “Green” Device (Note 3)
SMB 0.093 grams (Approximate)
Qualified to AEC-Q101 Standards for High Reliability SMA/SMB
Top View Bottom View
Ordering Information
(Note 4)
Part Number Qualification Case Packaging
B2xxA-13-F Standard SMA 5,000/Tape & Reel B2xx-13-F Standard SMB 3,000/Tape & Reel B250Q-13 Automotive SMB 3,000/Tape & Reel B240AQ-13-F Automotive SMA 5,000/Tape & Reel B240Q-13-F Automotive SMB 3,000/Tape & Reel * x = Device type, e.g. B260A-13-F (SMA package); B240-13-F (SMB package). Notes: 1. EU Directive 2002/95/EC (RoHS) & 2011/65/EU (RoHS 2) compliant. All applicable RoHS exemptions applied. 2. See http://www.diodes.com/quality/lead_free.html for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. 4. For packaging details, go to our website at http://www.diodes.com/products/packages.html. 5. Automotive products are AEC-Q101 qualified and are PPAP capable. Automotive, AEC-Q101 and standard products are electrically and thermally the same, except where specified. For more information, please refer to http://www.diodes.com/quality/product_compliance_definitions/.
Marking Information
B2X0A = Product type marking code, ex: B220A (SMA package) B2X0 = Product type marking code, ex: B230 (SMB package) = Manufacturers’ code marking YWW = Date code marking Y = Last digit of year (ex: 5 for 2015) WW = Week code (01 to 53) B220/A - B260/A 1 of 5 July 2015 Document number: DS13004 Rev. 22 - 2
www.diodes.com
© Diodes Incorporated
