Datasheet 1N914 (Vishay) - 2
ManufacturerVishay
DescriptionSmall Signal Fast Switching Diodes
Pages / Page3 / 2 — 1N914. ELECTRICAL CHARACTERISTICS. PARAMETER. TEST CONDITION. SYMBOL. …
Revision01-Jan-2021
File Format / SizePDF / 71 Kb
1N914. ELECTRICAL CHARACTERISTICS. PARAMETER. TEST CONDITION. SYMBOL. MIN. TYP. MAX. UNIT. TYPICAL CHARACTERISTICS. PACKAGE DIMENSIONS
1N914 ELECTRICAL CHARACTERISTICS PARAMETER TEST CONDITION SYMBOL MIN TYP MAX UNIT TYPICAL CHARACTERISTICS PACKAGE DIMENSIONS
1N914
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT
Forward voltage IF = 10 mA VF 1 V Breakdown voltage IR = 100 μA V(BR) 100 V VR = 75 V IR 5 μA Peak reverse current VR = 20 V, Tj = 150 °C IR 50 μA VR = 20 V IR 25 nA Diode capacitance VR = 0, f = 1 MHz CD 4 pF I Reverse recovery time F = 10 mA, iR = 1 mA, VR = 6 V, RL = 100 Ω trr 4 ns
(Tamb = 25 °C, unless otherwise specified) 1000 1000 1N914 100 T = 25 °C j 100 Scattering Limit 10 Scattering Limit 10 1 - Forward Current (mA) - Reverse Current (nA) I F I R T = 25 °C j 0.1 1 0 0.4 0.8 1.2 1.6 2.0 10 1 100 94 9170_1 V 94 9098 V - Reverse Voltage (V) F - Forward Voltage (V) R Fig. 1 - Forward Current vs. Forward Voltage Fig. 2 - Reverse Current vs. Reverse Voltage
PACKAGE DIMENSIONS
in millimeters (inches):
DO-35 (DO-204AH)
Cathode Identification ] ] 24] 7 0 .0 .015] 6 5 [0 .0 .0 [0 26 min. [1.024] 3.9 max. [0.154] 26 min. [1.024] 0 0 x. [ [ a in. 7 3 1. 1. 3.1 min. [0.120] 6 m 4 m 0. 0. Ø Ø Rev. 6 - Date: 19. December 2011 Document no.: SB-V-3906.04-031(4) 94 9366 Rev. 2.0, 24-Feb-2020
2
Document Number: 85622 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
