Datasheet SD101A, SD101B, SD101C (Vishay)
ManufacturerVishay
DescriptionSmall Signal Schottky Diodes
Pages / Page4 / 1 — SD101A, SD101B, SD101C. Small Signal Schottky Diodes. FEATURES. DESIGN …
File Format / SizePDF / 78 Kb
SD101A, SD101B, SD101C. Small Signal Schottky Diodes. FEATURES. DESIGN SUPPORT TOOLS. APPLICATIONS. MECHANICAL DATA. Case:. Weight:
Datasheet SD101A, SD101B, SD101C Vishay
Small Signal Schottky Diodes FEATURES
• Integrated protection ring against static discharge • Low capacitance • Low leakage current • Low forward voltage drop • AEC-Q101 qualified • Material categorization: for definitions of compliance please see www.vishay.com/doc?99912
click logo to get started
• HF-detector Models • Protection circuit Available • Diode for low currents with a low supply voltage
MECHANICAL DATA
• Small battery charger
Case:
DO-35 (DO-204AH) • Power supplies
Weight:
approx. 125 mg • DC/DC converter for notebooks
Cathode band color:
black
Packaging codes/options:
TR/10K per 13" reel (52 mm tape), 50K/box TAP/10K per ammopack (52 mm tape), 50K/box
PARTS TABLE CIRCUIT PART TYPE DIFFERENTATION ORDERING CODE TYPE MARKING REMARKS CONFIGURATION
V SD101A-TR or Tape and reel/ SD101A R = 60 V, VF max. 410 mV Single SD101A at IF = 1 mA SD101A-TAP ammopack V SD101B-TR or Tape and reel/ SD101B R = 50 V, VF max. 400 mV Single SD101B at IF = 1 mA SD101B-TAP ammopack V SD101C-TR or Tape and reel/ SD101C R = 40 V, VF max. 390 mV Single SD101C at IF = 1 mA SD101C-TAP ammopack
ABSOLUTE MAXIMUM RATINGS
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION PART SYMBOL VALUE UNIT
SD101A VR 60 V Reverse voltage SD101B VR 50 V SD101C VR 40 V Forward continuous current IF 30 mA Peak forward surge current tp = 10 μs IFSM 2 A Repetitive peak forward current IFRM 150 mA Power dissipation (1) Ptot 310 mW
Note
(1) Valid provided that electrodes are kept at ambient temperature
THERMAL CHARACTERISTICS
PARAMETER TEST CONDITION SYMBOL VALUE UNIT
Junction temperature Tj 125 °C Storage temperature range Tstg -65 to +150 °C Thermal resistance junction to ambient air (1) RthJA 320 K/W
Note
(1) Valid provided that electrodes are kept at ambient temperature Rev. 1.8, 01-Jun-17
1
Document Number: 85629 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
