Datasheet OP271 (Analog Devices) - 7
Description | High-Speed, Dual Operational Amplifier |
Pages / Page | 12 / 7 — OP271. 180. TA = 25. A = 25. 160. VS =. 15V. THD = 1%. 140. POSITIVE … |
File Format / Size | PDF / 884 Kb |
OP271. 180. TA = 25. A = 25. 160. VS =. 15V. THD = 1%. 140. POSITIVE SWING. L = 10k. 120. NEGATIVE SWING. 100. AV = 1. MAXIMUM OUTPUT – Volts
OP271 28 20 180 TA = 25 C T T 18 A = 25 C A = 25 C 160 24 VS = 15V VS = 15V VS = 15V THD = 1% 16 140 R POSITIVE SWING 20 L = 10k 14 120 16 12 NEGATIVE SWING 100 10 12 80 8 60 AV = 1 8 6 MAXIMUM OUTPUT – Volts OUTPUT IMPEDANCE – 40 4 4 PEAK-TO-PEAK AMPLITUDE – Volts A 2 20 V = 100 0 0 0 1k 10k 100k 1M 10M 100 1k 10k 100 1k 10k 100k 1M 10M FREQUENCY – Hz LOAD RESISTANCE – FREQUENCY – Hz
TPC 19. Maximum Output Swing TPC 20. Maximum Output Voltage TPC 21. Output Impedance vs. vs. Frequency vs. Load Resistance Frequency
12 190 V T S = 15V 180 A = 25 C VS = 15V 11 170 160 S 10 –SR 150 140 9 130 +SR 120 8 110 SLEW RATE – V/ 100 7 CHANNEL SEPARATION – dB 90 80 6 70 –75 –50 –25 0 25 50 75 100 125 10 100 1k 10k 100k 1M 10M TEMPERATURE – C FREQUENCY – Hz
TPC 22. Slew Rate vs. Temperature TPC 23. Channel Separation vs. Frequency
TA = 25 C TA = 25 C VS = 15V VS = 15V AV = +1 AV = +1 OBSOLETE 5V 5 s 50mV 200ns
TPC 24. Large-Signal Transient TPC 25. Small Signal Transient Response Response REV. A –7– Document Outline FEATURES GENERAL DESCRIPTION PIN CONNECTIONS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE Typical Performance Characteristics APPLICATION INFORMATION Capacitive Load Driving and Power Supply Considerations Unity-Gain Buffer Applications Computer Simulations APPLICATIONS Low Phase Error Amplifier Dual 12-Bit Voltage Output DAC Fast Current Pump OUTLINE DIMENSIONS Revision History
