Datasheet 2N3819 (ON Semiconductor) - 3
Manufacturer | ON Semiconductor |
Description | N-Channel RF Amplifier |
Pages / Page | 3 / 3 — TRADEMARKS. DISCLAIMER. LIFE SUPPORT POLICY. PRODUCT STATUS DEFINITIONS. … |
File Format / Size | PDF / 57 Kb |
TRADEMARKS. DISCLAIMER. LIFE SUPPORT POLICY. PRODUCT STATUS DEFINITIONS. Definition of Terms. Datasheet Identification
TRADEMARKS
The following are registered and unregistered trademarks Fairchild Semiconductor owns or is authorized to use and is not intended to be an exhaustive list of all such trademarks. ACEx™ FACT™ ImpliedDisconnect™ PACMAN™ SPM™ ActiveArray™ FACT Quiet series™ ISOPLANAR™ POP™ Stealth™ Bottomless™ FAST® LittleFET™ Power247™ SuperSOT™-3 CoolFET™ FASTr™ MicroFET™ PowerTrench® SuperSOT™-6 CROSSVOLT™ FRFET™ MicroPak™ QFET™ SuperSOT™-8 DOME™ GlobalOptoisolator™ MICROWIRE™ QS™ SyncFET™ EcoSPARK™ GTO™ MSX™ QT Optoelectronics™ TinyLogic™ E2CMOS™ HiSeC™ MSXPro™ Quiet Series™ TruTranslation™ EnSigna™ I2C™ OCX™ RapidConfigure™ UHC™ Across the board. Around the world.™ OCXPro™ RapidConnect™ UltraFET® The Power Franchise™ OPTOLOGIC® SILENT SWITCHER® VCX™ Programmable Active Droop™ OPTOPLANAR™ SMART START™
DISCLAIMER
FAIRCHILD SEMICONDUCTOR RESERVES THE RIGHT TO MAKE CHANGES WITHOUT FURTHER NOTICE TO ANY PRODUCTS HEREIN TO IMPROVE RELIABILITY, FUNCTION OR DESIGN. FAIRCHILD DOES NOT ASSUME ANY LIABILITY ARISING OUT OF THE APPLICATION OR USE OF ANY PRODUCT OR CIRCUIT DESCRIBED HEREIN; NEITHER DOES IT CONVEY ANY LICENSE UNDER ITS PATENT RIGHTS, NOR THE RIGHTS OF OTHERS.
LIFE SUPPORT POLICY
FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF FAIRCHILD SEMICONDUCTOR CORPORATION. As used herein: 1. Life support devices or systems are devices or systems 2. A critical component is any component of a life support which, (a) are intended for surgical implant into the body, device or system whose failure to perform can be or (b) support or sustain life, or (c) whose failure to perform reasonably expected to cause the failure of the life support when properly used in accordance with instructions for use device or system, or to affect its safety or effectiveness. provided in the labeling, can be reasonably expected to result in significant injury to the user.
PRODUCT STATUS DEFINITIONS Definition of Terms Datasheet Identification Product Status Definition
Advance Information Formative or In This datasheet contains the design specifications for Design product development. Specifications may change in any manner without notice. Preliminary First Production This datasheet contains preliminary data, and supplementary data will be published at a later date. Fairchild Semiconductor reserves the right to make changes at any time without notice in order to improve design. No Identification Needed Full Production This datasheet contains final specifications. Fairchild Semiconductor reserves the right to make changes at any time without notice in order to improve design. Obsolete Not In Production This datasheet contains specifications on a product that has been discontinued by Fairchild semiconductor. The datasheet is printed for reference information only. ©2002 Fairchild Semiconductor Corporation Rev. I1
