20V Digital Input Class-DG Amplifier with I/V Sense and Brownout Prevention
Pages / Page
172 /7 — link. to. page. 42. link. to. page. 42. link. to. page. 42. link. to. …
PDF / 2.6 Mb
link. to. page. 42. link. to. page. 42. link. to. page. 42. link. to. page. 43. link. to. page. 43. link. to. page. 45. link. to. page. 46. link. to. page. 48. link. to. page. 49. link. to. page
link to page 42 link to page 42 link to page 42 link to page 43 link to page 43 link to page 45 link to page 46 link to page 48 link to page 49 link to page 49 link to page 52 link to page 54 link to page 56 link to page 56 link to page 56 link to page 57 link to page 57 link to page 57 link to page 57 link to page 57 link to page 57 link to page 57 link to page 57 link to page 58 link to page 58 link to page 58 link to page 58 link to page 59 link to page 59 link to page 59 link to page 59 link to page 59 link to page 59 link to page 59 link to page 59 link to page 60 link to page 60 link to page 60 link to page 61 link to page 61 link to page 61 link to page 61 link to page 62 link to page 62 link to page 62 link to page 63 link to page 63 link to page 63 link to page 64 link to page 64 link to page 65 link to page 65 link to page 65 link to page 65 link to page 66 link to page 66 link to page 66 link to page 66 link to page 67 link to page 67 link to page 68 link to page 68 link to page 72 link to page 75 link to page 76 link to page 77 link to page 77 link to page 81 link to page 82 link to page 82 link to page 83 link to page 83 link to page 83 link to page 83 link to page 84 link to page 84 link to page 84 link to page 84 link to page 85 link to page 85 MAX98396 20V Digital Input Class-DG Amplifier with I/V Sense and Brownout Prevention LIST OF FIGURES Figure 1. Standard I2S Mode . 42 Figure 2. Left-Justified Mode . 42 Figure 3. Left-Justified Mode (LRCLK Inverted) . 43 Figure 4. Left-Justified Mode (BCLK Inverted) . 43 Figure 5. TDM Modes . 45 Figure 6. PCM Data Input . 46 Figure 7. I/V Sense Path Data Interleaved on a Single Data Output Channel . 48 Figure 8. PCM Interface Timing/Slave Mode—LRCLK, BCLK, DIN Timing Diagram . 49 Figure 9. PCM Interface Timing/DOUT Timing Diagram . 49 Figure 10. Speaker Signal Path Diagram . 52 Figure 11. Simplified Dynamic-Headroom Tracking System Block Diagram . 54 Figure 12. VTPO and ATPO Calculation Example . 56 Figure 13. Signal Distortion Limiter with VMPO ≤ VSUP and +20% Headroom (SUPHR) . 57 Figure 14. Signal Distortion Limiter with VMPO ≤ VSUP and 0% Headroom (SUPHR) . 57 Figure 15. Signal Distortion Limiter with VMPO ≤ VSUP and -20% Headroom (SUPHR) . 58 Figure 16. Signal Distortion Limiter with VMPO > VSUP and +20% Headroom (SUPHR) . 59 Figure 17. Signal Distortion Limiter with VMPO > VSUP and 0% Headroom (SUPHR) . 59 Figure 18. Signal Distortion Limiter with VMPO > VSUP and -20% Headroom (SUPHR) . 60 Figure 19. Signal Level Limiter with VTPO > VSLL as VSUP Decreases . 61 Figure 20. Signal Level Limiter with VTPO < VSLL Showing Amplifier Output Clipping . 62 Figure 21. Dynamic Range Compression with Decreasing VSUP and SUPHR ≥ 0% . 63 Figure 22. Dynamic Range Compressor with SUPHR < 0% and Output Clipping . 64 Figure 23. DHT DRC and SLL with Decreasing VSUP (VTPO), and SUPHR ≥ 0% . 65 Figure 24. DHT DRC and SLL with Decreasing VSUP (VTPO), and SUPHR < 0% . 66 Figure 25. Distortion Limiter Case with -20% Headroom and AMAX Exceeded . 67 Figure 26. Distortion Limiter Case with +20% Headroom and AMAX Exceeded . 68 Figure 27. BPE Block Diagram . 72 Figure 28. Data Monitor Error Generation due to Input Data Stuck Error Detection . 75 Figure 29. Monitor Error Generation due to Input Data Magnitude Error Detection . 76 Figure 30. Clock Monitor LRCLK Rate Error Example With CMON_ERRTOL = 0x1 . 77 Figure 31. Clock Monitor Framing Error Example In TDM Mode With PCM_BSEL = 0x6 and CMON_BSELTOL = 0x0 77 Figure 32. ICC Multi-Group Example with 2 Groups and 4 Total Devices . 81 Figure 33. I2C Interface Timing Diagram . 82 Figure 34. I2C START, STOP, and REPEATED START Conditions . 83 Figure 35. I2C Acknowledge . 83 Figure 36. I2C Writing One Byte of Data to the Slave . 84 Figure 37. I2C Writing n-Bytes of Data to the Slave . 84 Figure 38. I2C Reading One Byte of Data from the Slave . 85 www.maximintegrated.com Maxim Integrated | 7 Document Outline General Description Applications Benefits and Features Simplified Block Diagram Absolute Maximum Ratings Package Information 35 WLP Electrical Characteristics Electrical Characteristics (continued) Typical Operating Characteristics Typical Operating Characteristics (continued) Pin Configuration 35 WLP Pin Description Pin Description (continued) Functional Diagrams Detailed Block Diagram Detailed Description Device State Control Hardware Shutdown State Software Shutdown State Active State Device Sequencing PCM Interface PCM Clock Configuration PCM Data Format Configuration I2S/Left-Justified Mode TDM Modes PCM Data Path Configuration PCM Data Input PCM Data Output Data Output Channel-Interleaved I/V Sense Data Data Output Status Bits PCM Interface Timing Interrupts Interrupt Bit Field Composition Interrupt Output Configuration Interrupt Sources Speaker Path Speaker Path Block Diagram Speaker Playback Path Speaker Path Noise Gate Speaker Path Dither Speaker Path Data Inversion Speaker Path DC Blocking Filter Speaker Path Digital Volume Control Speaker Path Digital Gain Control Speaker Path DSP Data Feedback Path Speaker Safe Mode Speaker Audio Processing Bypass Path Bypass Path Data Inversion Bypass Path Dither Bypass Path DC Blocking Filter Speaker Maximum Peak Output Voltage Scaling Dynamic-Headroom Tracking (DHT) DHT Supply Tracking and Headroom DHT Mode 1 – Signal Distortion Limiter DHT Mode 2 – Signal Level Limiter DHT Mode 3: Dynamic Range Compressor DHT Mode 4: Dynamic Range Compressor with Signal Level Limiter DHT Attenuation DHT Attenuation Reporting DHT Ballistics Speaker Amplifier Speaker Amplifier Operating Modes Class-DG Mode Enabled Delay for DG Mode Class-DG Mode Disabled NOVBAT Mode IDLE Mode Speaker Amplifier Ultra-Low EMI Filterless Operation Speaker Amplifier Overcurrent Protection Speaker Current and Voltage Sense ADC Path Brownout-Prevention Engine BPE State Controller and Level Thresholds BPE Level Configuration Options BPE Gain Attenuation Function BPE Limiter Function Brownout Interrupts Measurement ADC Measurement ADC Thermal Channel Measurement ADC PVDD Channel Measurement ADC VBAT Channel Clock and Data Monitors Input Data Monitor Clock Monitor Clock Activity and Frequency Detection Clock Frame Error Detection Speaker Monitor Thermal Protection Thermal Warning and Thermal Shutdown Configuration Thermal Shutdown Recovery Configuration Thermal Foldback Tone Generator Pink Noise Generator Interchip Communication ICC Operation and Data Format Multiamplifier Grouping I2C Serial Interface Slave Address Bit Transfer START and STOP Conditions Early STOP Conditions Acknowledge Write Data Format Read Data Format I2C Register Map Control Bit Field Types and Write Access Restrictions Register Map Register Map Register Details Software Reset (0x2000) Interrupt Raw 1 (0x2001) Interrupt Raw 2 (0x2002) Interrupt Raw 3 (0x2003) Interrupt Raw 4 (0x2004) Interrupt State 1 (0x2006) Interrupt State 2 (0x2007) Interrupt State 3 (0x2008) Interrupt State 4 (0x2009) Interrupt Flag 1 (0x200B) Interrupt Flag 2 (0x200C) Interrupt Flag 3 (0x200D) Interrupt Flag 4 (0x200E) Interrupt Enable 1 (0x2010) Interrupt Enable 2 (0x2011) Interrupt Enable 3 (0x2012) Interrupt Enable 4 (0x2013) Interrupt Flag Clear 1 (0x2015) Interrupt Flag Clear 2 (0x2016) Interrupt Flag Clear 3 (0x2017) Interrupt Flag Clear 4 (0x2018) IRQ Control (0x201F) Thermal Warning Threshhold (0x2020) Warning Threshold 2 (0x2021) Thermal Shutdown Threshold (0x2022) Thermal Hysteresis (0x2023) Thermal Foldback Settings (0x2024) Thermal Foldback Enable (0x2027) Noise Gate/Idle Mode Control (0x2030) Noise Gate/Idle Mode Enables (0x2033) Clock Monitor Control (0x2038) Data Monitor Control (0x2039) Speaker Monitor Threshold (0x203A) Speaker Monitor Duration (0x203B) Enable Controls (0x203F) Pin Config (0x2040) PCM Mode Config (0x2041) PCM Clock Setup (0x2042) PCM Sample Rate Setup 1 (0x2043) PCM TX Control 1 (0x2044) PCM TX Control 2 (0x2045) PCM TX Control 3 (0x2046) PCM TX Control 4 (0x2047) PCM TX Control 5 (0x2048) PCM TX Control 6 (0x2049) PCM TX Control 7 (0x204A) PCM TX Control 8 (0x204B) PCM Tx HiZ Control 1 (0x204C) PCM Tx HiZ Control 2 (0x204D) PCM Tx HiZ Control 3 (0x204E) PCM Tx HiZ Control 4 (0x204F) PCM Tx HiZ Control 5 (0x2050) PCM Tx HiZ Control6 (0x2051) PCM Tx HiZ Control 7 (0x2052) PCM Tx HiZ Control 8 (0x2053) PCM RX Source 1 (0x2055) PCM RX Source 2 (0x2056) PCM Bypass Source (0x2058) PCM TX Source Enables (0x205D) PCM Rx Enables (0x205E) PCM Tx Enables (0x205F) ICC Rx Enables A (0x2070) ICC Rx Enables B (0x2071) ICC Tx Control (0x2072) ICC Enables (0x207F) Tone Generator and DC Config (0x2083) Tone Generator DC Level 1 (0x2084) Tone Generator DC Level 2 (0x2085) Tone Generator DC Level 3 (0x2086) Tone Generator Enable (0x208F) AMP volume control (0x2090) AMP Path Gain (0x2091) AMP DSP Config (0x2092) SSM Configuration (0x2093) SPK Class DG Threshold (0x2094) SPK Class DG Headroom (0x2095) SPK Class DG Hold Time (0x2096) SPK Class DG Delay (0x2097) SPK Class DG Mode (0x2098) SPK Class DG VBAT Level (0x2099) SPK Edge Control (0x209A) SPK Path Wideband Only Enable (0x209B) SPK Edge Control 1 (0x209C) SPK Edge Control 2 (0x209D) Amp Clip Gain (0x209E) Bypass Path Config (0x209F) Amplifier Supply Control (0x20A0) AMP enables (0x20AF) Meas ADC Sample Rate (0x20B0) Meas ADC PVDD Config (0x20B1) Meas ADC VBAT Config (0x20B2) Meas ADC Thermal Config (0x20B3) Meas ADC Readback Control 1 (0x20B4) Meas ADC Readback Control 2 (0x20B5) Meas ADC PVDD Readback MSB (0x20B6) Meas ADC PVDD Readback LSB (0x20B7) Meas ADC VBAT Readback MSB (0x20B8) Meas ADC VBAT Readback LSB (0x20B9) Meas ADC Temp Readback MSB (0x20BA) Meas ADC Temp Readback LSB (0x20BB) Meas ADC Lowest PVDD Readback MSB (0x20BC) Meas ADC Lowest PVDD Readback LSB (0x20BD) Meas ADC Lowest VBAT Readback MSB (0x20BE) Meas ADC Lowest VBAT Readback LSB (0x20BF) Meas ADC Config (0x20C7) DHT Configuration 1 (0x20D0) Limiter Configuration 1 (0x20D1) Limiter Configuration 2 (0x20D2) DHT Configuration 2 (0x20D3) DHT Configuration 3 (0x20D4) DHT Configuration 4 (0x20D5) DHT Supply Hysteresis Configuration (0x20D6) DHT Enable (0x20DF) I_V Sense Path Config (0x20E0) I_V Sense Path Enables (0x20E4) BPE State (0x20E5) BPE L3 Threshold MSB (0x20E6) BPE L3 Threshold LSB (0x20E7) BPE L2 Threshold MSB (0x20E8) BPE L2 Threshold LSB (0x20E9) BPE L1 Threshold MSB (0x20EA) BPE L1 Threshold LSB (0x20EB) BPE L0 Threshold MSB (0x20EC) BPE L0 Threshold LSB (0x20ED) BPE L3 Dwell and Hold Time (0x20EE) BPE L2 Dwell and Hold Time (0x20EF) BPE L1 Dwell and Hold Time (0x20F0) BPE L0 Hold Time (0x20F1) BPE L3 Attack and Release Step (0x20F2) BPE L2 Attack and Release Step (0x20F3) BPE L1 Attack and Release Step (0x20F4) BPE L0 Attack and Release Step (0x20F5) BPE L3 Max Gain Attn (0x20F6) BPE L2 Max Gain Attn (0x20F7) BPE L1 Max Gain Attn (0x20F8) BPE L0 Max Gain Attn (0x20F9) BPE L3 Gain Attack and Rls Rates (0x20FA) BPE L2 Gain Attack and Rls Rates (0x20FB) BPE L1 Gain Attack and Rls Rates (0x20FC) BPE L0 Gain Attack and Rls Rates (0x20FD) BPE L3 Limiter Config (0x20FE) BPE L2 Limiter Config (0x20FF) BPE L1 Limiter Config (0x2100) BPE L0 Limiter Config (0x2101) BPE L3 Limiter Attack and Release Rates (0x2102) BPE L2 Limiter Attack and Release Rates (0x2103) BPE L1 Limiter Attack and Release Rates (0x2104) BPE L0 Limiter Attack and Release Rates (0x2105) BPE Threshold Hysteresis (0x2106) BPE Infinite Hold Clear (0x2107) BPE Supply Source (0x2108) BPE Lowest State (0x2109) BPE Lowest Gain (0x210A) BPE Lowest Limiter (0x210B) BPE Enable (0x210D) Auto-Restart Behavior (0x210E) Global Enable (0x210F) Revision ID (0x21FF) Applications Information Layout and Grounding Recommended External Components Typical Application Circuits Typical Application Circuit Ordering Information Revision History
