Datasheet 2N1651, 2N1652, 2N1653, 2N2285, 2N2286, 2N2287 (Motorola) - 2
Manufacturer | Motorola |
Description | PNP Germanium power transistor |
Pages / Page | 2 / 2 — 2N1651 thru 2N1653/2N2285 thru 2N2287 (continued). ELECTRICAL … |
File Format / Size | PDF / 124 Kb |
2N1651 thru 2N1653/2N2285 thru 2N2287 (continued). ELECTRICAL CHARACTERISTICS I (Tc =2SC unless otherwise noted)
ELECTRICAL CHARACTERISTICS I (Tc =2S"C unless otherwise noted)
Symbol Characteristic Min Max 30
60
80 -40
45
50 -200 5.0 OFF CHARACTERISTICS
Collector-Emitter Breakdown Voltage
(IC = 100 mAdc, IB = 0) 2N1651, 2N2285
2N1652, 2N2286
2N1653, 2N2287 Collector-Emitter Sustaimng Voltage (See Figure 1)
(IC = 25 Adc) 2N1651, 2N2285
2N1652, 2N2286
2N1653, 2N2287 Collector Cutoff Current
(V CB =2.0Vdc, IE =0) BV CEO VCE(sus) ICB01 2N1651, 2N2285 (V CB = 80 Vdc, IE = 0)' 2N1652, 2N2286 -(V CB = 100 Vdc, IE = 0) 2N1653, 2N2287 -5.0 -35 -35 Collector Cutoff Current
(V CB = 40 Vdc, IE = 0, TC = 100'C) (+0,-3. O'C) 2N1651, 2N2285 (V CB = 80 Vdc, IE = 0, T C = 100° C) (+0,"3. O' C) 2N1652, 2N2286 (V CB = 100 Vdc, IE = 0, TC = l(lO'C) (+0, -3.0' C) 2N1653, 2N2287 Collector Cutoff Current
(V CB = 60 Vdc, IE = 0) 2N1651, 2N2285 (V CB = 100 Vdc, IE = 0) 2N1652, 2N2286 (V CB = 120 Vdc, IE = 0) 2N1653, 2N2287 Emitter Cutoff Current
(V EB = 1. 5 Vdc, IC = 0) I CB03 Vdc /lAdc Collector Cutoff Current
(VCB = 40 Vdc, ~ = 0) ICB02 Vdc mAdc
5.0 mAdc I CB04 lEBO 35 mAdc -20 -50 35 140 20 -20
20
mAdc ON CHARACTERISTICS
DC Current Gain
(IC = 10 A4c, V CE = 2.0 Vdc) hFE (IC = 25 Adc, VCE = 1. 5 Vdc) -Collector-Emitter Saturation Voltage
(IC = 25 Adc, IB = 2.5 Adc) VCE(sat) -0.30 Base-Emitter Saturation Voltage
(IC = 25 Adc, IB = 2.5 Adc) VBE(sat) -0.65 Vdc
Vdc SMALL SIGNAL CHARACTERISTICS
Small-Signal Current Gain
(IC = 0.5 Adc, V CE = 6.0 Vdc, f = 30 kHz) SWITCHING CHARACTERISTICS
Rise Time tr -12 /ls Storage Time t s -10 /lS tf -8.0 /lS Fall Time (IC = 25 Adc, IB(on) = 2. 5 Adc, IB(off) = 2.5 Adc)
(See Figure 2) FIGURE 2 -SWITCHING TIME TEST CIRCUIT
1.1
SCOPE D-_-'VV'Ir-,
PULSE WIDTH = 50 IlS
DUTY CYCLE = 10% Adjfor ISlon)= 2.5 A
~ 12V rUT
~28V PULSE
GENERATDRO-_ _ _ _ _ _~_ _ _ _ _ _ _~_~~_ _ _~-_ 2-208 _J Adj
IC = 25 A
