Datasheet ADuM1100 (Analog Devices)
DescriptioniCoupler Digital Isolator
Pages / Page20 / 1 — Coupler Digital Isolator. Data Sheet. ADuM1100. FEATURES. GENERAL …
RevisionK
File Format / SizePDF / 420 Kb
Coupler Digital Isolator. Data Sheet. ADuM1100. FEATURES. GENERAL DESCRIPTION. High data rate: dc to 100 Mbps (NRZ)
Datasheet ADuM1100 Analog Devices, Revision: K
i
Coupler Digital Isolator Data Sheet ADuM1100 FEATURES GENERAL DESCRIPTION High data rate: dc to 100 Mbps (NRZ)
The ADuM11001 is a digital isolator based on Analog Devices
Compatible with 3.3 V and 5.0 V operation/level translation
Inc., iCoupler® technology. Combining high speed CMOS and
125°C maximum operating temperature
monolithic air core transformer technology, this isolation
Low power operation
component provides outstanding performance characteristics
5 V operation
superior to alternatives, such as optocoupler devices.
1.0 mA maximum @ 1 Mbps
Configured as a pin-compatible replacement for existing high
4.5 mA maximum @ 25 Mbps
speed optocouplers, the ADuM1100 supports data rates as high
16.8 mA maximum @ 100 Mbps
as 25 Mbps and 100 Mbps.
3.3 V operation 0.4 mA maximum @ 1 Mbps
The ADuM1100 operates with a voltage supply ranging from
3.5 mA maximum @ 25 Mbps
3.0 V to 5.5 V, boasts a propagation delay of <18 ns and edge
7.1 mA maximum @ 50 Mbps
asymmetry of <2 ns, and is compatible with temperatures up
8-lead SOIC_N package (RoHS compliant version available)
to 125°C. It operates at very low power, less than 0.9 mA of
High common-mode transient immunity: >25 kV/μs
quiescent current (sum of both sides), and a dynamic current
Safety and regulatory approvals
of less than 160 μA per Mbps of data rate. Unlike other optocoupler
UL recognized
alternatives, the ADuM1100 provides dc correctness with a
2500 V rms for 1 minute per UL 1577
patented refresh feature that continuously updates the output
CSA Component Acceptance Notice 5A
signal.
VDE Certificate of Conformity
The ADuM1100 is offered in three grades. The ADuM1100AR
DIN V VDE V 0884-10 (VDE V 0884-10):2006-12
and ADuM1100BR can operate up to a maximum temperature
VIORM = 560 V peak
of 105°C and support data rates up to 25 Mbps and 100 Mbps,
respectively. The ADuM1100UR can operate up to a maximum temperature of 125°C and supports data rates up to 100 Mbps.
Digital field bus isolation Opto-isolator replacement Computer peripheral interface Microprocessor system interface General instrumentation and data acquisition applications FUNCTIONAL BLOCK DIAGRAM VDD1 1 8 VDD2 E D N E V C C I 2 7 GND (DATA IN) O O 2 D D E E V 6 O VDD1 3 (DATA OUT) UPDATE WATCHDOG GND1 4 5 GND2 ADuM1100 NOTES
001
1. FOR PRINCIPLES OF OPERATION, SEE METHOD OF OPERATION, DC CORRECTNESS, AND MAGNETIC FIELD IMMUNITY SECTION.
02462- Figure 1. 1 Protected by U.S. Patents 5,952,849; 6,525,566; 6,922,080; 6,903,578; 6,873,065; 7,075,329.
Rev. K Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2015 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS—5 V OPERATION ELECTRICAL SPECIFICATIONS—3.3 V OPERATION ELECTRICAL SPECIFICATIONS—MIXED 5 V/3 V OR 3 V/5 V OPERATION PACKAGE CHARACTERISTICS REGULATORY INFORMATION INSULATION AND SAFETY-RELATED SPECIFICATIONS DIN V VDE V 0884-10 (VDE V 0884-10):2006-12 INSULATION CHARACTERISTICS RECOMMENDED OPERATING CONDITIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATION INFORMATION PC BOARD LAYOUT PROPAGATION DELAY-RELATED PARAMETERS METHOD OF OPERATION, DC CORRECTNESS, AND MAGNETIC FIELD IMMUNITY POWER CONSUMPTION OUTLINE DIMENSIONS ORDERING GUIDE
