Datasheet ADuM1100 (Analog Devices) - 9
DescriptioniCoupler Digital Isolator
Pages / Page20 / 9 — Data Sheet. ADuM1100. Parameter. Symbol. Min. Typ. Max. Unit. Test …
RevisionK
File Format / SizePDF / 420 Kb
Data Sheet. ADuM1100. Parameter. Symbol. Min. Typ. Max. Unit. Test Conditions
Data Sheet ADuM1100 Parameter Symbol Min Typ Max Unit Test Conditions
link to page 14 link to page 14 link to page 18 link to page 16 link to page 16 link to page 17 link to page 14 link to page 14 link to page 18 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9
Pulse Width Distortion, |tPLH − tPHL|5 PWD 5 V/3 V Operation 0.5 2 ns CL = 15 pF, CMOS signal levels 3 V/5 V Operation 0.5 3 ns CL = 15 pF, CMOS signal levels Change in Pulse Width Distortion vs. Temperature6 5 V/3 V Operation 3 ps/°C CL = 15 pF, CMOS signal levels 3 V/5 V Operation 10 ps/°C CL = 15 pF, CMOS signal levels Propagation Delay Skew (Equal tPSK1 Temperature)5, 7 5 V/3 V Operation 12 ns CL = 15 pF, CMOS signal levels 3 V/5 V Operation 15 ns CL = 15 pF, CMOS signal levels Propagation Delay Skew (Equal tPSK2 Temperature, Supplies)5, 7 5 V/3 V Operation 9 ns CL = 15 pF, CMOS signal levels 3 V/5 V Operation 12 ns CL = 15 pF, CMOS signal levels Output Rise/Fall Time (10% to 90%) tR, tF 3 ns CL = 15 pF, CMOS signal levels Common-Mode Transient Immunity at |CML|, 25 35 kV/µs VI = 0 V or VDD1, VCM = 1000 V, Logic Low/High Output8 |CMH| transient magnitude = 800 V Refresh Rate fr 5 V/3 V Operation 1.2 Mbps 3 V/5 V Operation 1.1 Mbps Input Dynamic Supply Current9 CPD1 5 V/3 V Operation 0.09 mA/Mbps 3 V/5 V Operation 0.08 mA/Mbps Output Dynamic Supply Current9 CPD2 5 V/3 V Operation 0.04 mA/Mbps 3 V/5 V Operation 0.02 mA/Mbps 1 Output supply current values are with no output load present. See Figure 5 and Figure 6 for information on supply current variation with logic signal frequency. See the Power Consumption section for guidance on calculating the input and output supply currents for a given data rate and output load. 2 The minimum pulse width is the shortest pulse width at which the specified pulse width distortion is guaranteed. 3 The maximum data rate is the fastest data rate at which the specified pulse width distortion is guaranteed. 4 tPHL is measured from the 50% level of the falling edge of the VI signal to the 50% level of the falling edge of the VO signal. tPLH is measured from the 50% level of the rising edge of the VI signal to the 50% level of the rising edge of the VO signal. 5 Because the input thresholds of the ADuM1100 are at voltages other than the 50% level of typical input signals, the measured propagation delay and pulse width distortion can be affected by slow input rise/fal times. See the Propagation Delay-Related Parameters section and Figure 14 through Figure 18 for information on the impact of given input rise/fall times on these parameters. 6 Pulse width distortion change vs. temperature is the absolute value of the change in pulse width distortion for a 1°C change in operating temperature. 7 tPSK1 is the magnitude of the worst-case difference in tPHL and/or tPLH that is measured between units at the same operating temperature and output load within the recommended operating conditions. tPSK2 is the magnitude of the worst-case difference in tPHL and/or tPLH that is measured between units at the same operating temperature, supply voltages, and output load within the recommended operating conditions. 8 CMH is the maximum common-mode voltage slew rate that can be sustained while maintaining VO > 0.8 VDD2. CML is the maximum common-mode voltage slew rate that can be sustained while maintaining VO < 0.8 V. The common-mode voltage slew rates apply to both rising and fal ing edges. The transient magnitude is the range over which the common mode is slewed. 9 Dynamic supply current is the incremental amount of supply current required for a 1 Mbps increase in signal data rate. See Figure 5 and Figure 6 for information on supply current variation with logic signal frequency. See the Power Consumption section for guidance on calculating the input and output supply currents for a given data rate and output load. Rev. K | Page 9 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS—5 V OPERATION ELECTRICAL SPECIFICATIONS—3.3 V OPERATION ELECTRICAL SPECIFICATIONS—MIXED 5 V/3 V OR 3 V/5 V OPERATION PACKAGE CHARACTERISTICS REGULATORY INFORMATION INSULATION AND SAFETY-RELATED SPECIFICATIONS DIN V VDE V 0884-10 (VDE V 0884-10):2006-12 INSULATION CHARACTERISTICS RECOMMENDED OPERATING CONDITIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATION INFORMATION PC BOARD LAYOUT PROPAGATION DELAY-RELATED PARAMETERS METHOD OF OPERATION, DC CORRECTNESS, AND MAGNETIC FIELD IMMUNITY POWER CONSUMPTION OUTLINE DIMENSIONS ORDERING GUIDE
