Datasheet L200 (STMicroelectronics) - 3
DescriptionAdjustable Voltage and Current Regulator
Pages / Page12 / 3 — L200. SCHEMATIC DIAGRAM. ELECTRICAL CHARACTERISTICS. Symbol. Parameter. …
File Format / SizePDF / 254 Kb
L200. SCHEMATIC DIAGRAM. ELECTRICAL CHARACTERISTICS. Symbol. Parameter. Test Conditions. Min. Typ. Max. Unit. VOLTAGE REGULATION LOOP
L200 SCHEMATIC DIAGRAM ELECTRICAL CHARACTERISTICS Symbol Parameter Test Conditions Min Typ Max Unit VOLTAGE REGULATION LOOP
(Tamb = 25 °C, unless otherwise specified)
Symbol Parameter Test Conditions Min. Typ. Max. Unit VOLTAGE REGULATION LOOP
Id Quiescent drain Current (pin 3) Vi = 20 V 4.2 9.2 mA eN Output Noise Voltage Vo = Vref Io = 10 mA µV B = 1 MHz 80 Vo Output Voltage Range Io = 10 mA 2.85 36 V ∆ Vo Voltage Load Regulation ∆Io = 2 A 0.15 1 % V (note 1) ∆I 0.1 0.9 % o o = 1.5 A ∆ Vi Line Regulation V0 = 5 V ∆ V Vi = 8 to 18 V 48 60 dB o SVR Supply Voltage Rejection V0 = 5 V Io = 500 mA ∆Vi = 10 Vpp f = 100 Hz (note 2) 48 60 dB ∆Vi-o Droupout Voltage between Pins 1 Io = 1.5 A ∆V0 ≤ 2% 2 2.5 V and 5 Vref Reference Voltage (pin 4) Vi = 20 V Io = 10 mA 2.64 2.77 2.86 V 3/12
