Datasheet PMG1-S0 (Infineon) - 8
ManufacturerInfineon
DescriptionPower Delivery Microcontroller Gen1
Pages / Page34 / 8 — PMG1-S0 Datasheet. Development Support. Technical Reference Manual:. …
PMG1-S0 Datasheet. Development Support. Technical Reference Manual:. Documentation. Online. Software User Guide:. Tools
PMG1-S0 Datasheet Development Support Technical Reference Manual: Documentation Online Software User Guide: Tools
The PMG1 family has a rich set of documentation, development
The Technical Reference tools, and online resources to assist you during your devel- Manual (TRM) contains all the technical detail you need to use a opment process. Visit www.cypress.com/products/ez-pd-pmg1 PMG1 device, including a complete description of all PMG1 to find out more. registers. The TRM is available in the Documentation section at www.cypress.com/products/ez-pd-pmg1.
Documentation
A suite of documentation supports the PMG1 family to ensure
Online
that you can find answers to your questions quickly. This section In addition to print documentation, the Cypress PMG1 forums contains a list of some of the key documents. connect you with fellow users and experts in PMG1 from around
A step-by-step guide for using Modus the world, 24 hours a day, 7 days a week. Toolbox (MTB). The software user guide shows you how MTB
Tools
build process works in detail, how to use source control with MTB, and much more. With industry standard cores, programming, and debugging
Component Datasheets:
The flexibility of PMG1 allows the interfaces, the PMG1 family is part of a development tool ecosystem. creation of new peripherals (components) long after the device has gone into production. Component data sheets provide all the Visit us at https://www.cypress.com/products/modus- information needed to select and use a particular component, toolbox-software-environment for the latest information on the including functional description, API documentation, example revolutionary, easy to use ModusToolbox IDE, supported third codes, and AC/DC specifications. party compilers, programmers, debuggers, and development kits.
Application Notes:
This includes the Getting Started application note and the Hardware Design Guidelines. Document Number: 002-31596 Rev. *B Page 7 of 33 Document Outline PMG1-S0 Datasheet, Power Delivery Microcontroller Gen1 PMG1 Family General Description PMG1-S0 General Description Features Type-C Support and USB-PD Support Legacy/Proprietary Charging Block System-Level Fault Protection 32-bit MCU Subsystem Clocks and Oscillators Power System-Level ESD Protection Packages Block Diagram Contents Development Support Documentation Online Tools ModusToolbox™ IDE and PMG1 SDK Functional Overview MCU Subsystem CPU Flash SROM USB-PD Subsystem (SS) USB-PD Physical Layer ADC Charger Detection VBUS Undervoltage and Overvoltage Protection VBUS Short Protection PFET Gate Drivers on VBUS Path VBUS Discharge FETs Integrated Digital Blocks Serial Communication Blocks (SCB) Timer/Counter/PWM Block (TCPWM) I/O Subsystem Power Systems Overview Pinouts Application Diagram Electrical Specifications Absolute Maximum Ratings Device-Level Specifications I/O Digital Peripherals Pulse Width Modulation (PWM) for GPIO Pins I2C System Resources Power-on-Reset (POR) with Brown Out SWD Interface Internal Main Oscillator Internal Low-Speed Oscillator Power Down Gate Driver Specifications Analog to Digital Converter Memory Ordering Information Ordering Code Definitions Packaging Acronyms Document Conventions Units of Measure Document History Page Sales, Solutions, and Legal Information Worldwide Sales and Design Support Products PSoC® Solutions Cypress Developer Community Technical Support
