Datasheet PMG1-S1 (Infineon) - 8
ManufacturerInfineon
DescriptionPower Delivery Microcontroller Gen1
Pages / Page41 / 8 — PMG1-S1 Datasheet. Development Support. Technical Reference Manual:. …
PMG1-S1 Datasheet. Development Support. Technical Reference Manual:. Documentation. Online. Software User Guide:. Tools
PMG1-S1 Datasheet Development Support Technical Reference Manual: Documentation Online Software User Guide: Tools
The PMG1 family has a rich set of documentation, development
The Technical Reference tools, and online resources to assist you during your devel- Manual (TRM) contains all the technical detail you need to use a opment process. Visit www.cypress.com/products/ez-pd-pmg1 PMG1 device, including a complete description of all PMG1 to find out more. registers. The TRM is available in the Documentation section at www.cypress.com/products/ez-pd-pmg1.
Documentation
A suite of documentation supports the PMG1 family to ensure
Online
that you can find answers to your questions quickly. This section In addition to print documentation, the Cypress PMG1 forums contains a list of some of the key documents. connect you with fellow users and experts in PMG1 from around
A step-by-step guide for using Modus the world, 24 hours a day, 7 days a week. Toolbox (MTB). The software user guide shows you how MTB
Tools
build process works in detail, how to use source control with MTB, and much more. With industry standard cores, programming, and debugging
Component Datasheets:
The flexibility of PMG1 allows the interfaces, the PMG1 family is part of a development tool ecosystem. creation of new peripherals (components) long after the device has gone into production. Component data sheets provide all the Visit us at https://www.cypress.com/products/modus- information needed to select and use a particular component, toolbox-software-environment for the latest information on the including functional description, API documentation, example revolutionary, easy to use ModusToolbox IDE, supported third codes, and AC/DC specifications. party compilers, programmers, debuggers, and development kits.
Application Notes:
This includes the Getting Started application note and the Hardware Design Guidelines. Document Number: 002-31597 Rev. *B Page 7 of 40 Document Outline PMG1-S1 Datasheet, Power Delivery Microcontroller Gen1 PMG1 Family General Description PMG1-S1 General Description Features USB-PD Type-C Legacy Charging (source and sink) Mux Integrated VBUS Load Switch Controller LDO 32-bit MCU Subsystem Integrated Digital Blocks Authentication Clocks and Oscillators Operating Range Hot-Swappable I/Os Packages Block Diagram Contents Development Support Documentation Online Tools ModusToolbox™ IDE and PMG1 SDK Functional Overview USB-PD Subsystem (SS) USB-PD Physical Layer VCONN FET ADC USB 2.0 Mux VBUS Discharge VBUS Regulator Gate Driver for VBUS PFET on Consumer Path Charger Detect High-Voltage Tolerant CC Lines VBUS Load Switch Controller for Provider Path RCP CSA Slew-Rate Controllable Gate Driver Overvoltage and Undervoltage Protection on VBUS Overcurrent Protection on VBUS True Random Number Generator CPU and Memory Subsystem CPU Flash SROM SRAM Peripherals Timer/Counter/PWM Block (TCPWM) GPIO Power System Overview Pinouts Application Diagrams Electrical Specifications Absolute Maximum Ratings Device-Level Specifications DC Specifications CPU GPIO XRES Digital Peripherals Pulse Width Modulation (PWM) for GPIO Pins I2C UART SPI Memory System Resources Power-on-Reset (POR) with Brown Out SWD Interface Internal Main Oscillator Internal Low-speed Oscillator PD Analog-to-Digital Converter Charger Detect VSYS Switch CSA VBUS UV/OV Consumer Side PFET Gate Driver Provider Side PFET Gate Driver Provider Side PFET RCP DP/DM Switch VCONN Switch VBUS Ordering Information Ordering Code Definitions Packaging Acronyms Document Conventions Units of Measure Document History Page Sales, Solutions, and Legal Information Worldwide Sales and Design Support Products PSoC® Solutions Cypress Developer Community Technical Support
