Datasheet MAX4100, MAX4101 (Maxim) - 6
Manufacturer | Maxim |
Description | 500MHz, Low-Power Op Amps |
Pages / Page | 12 / 6 — 500MHz, Low-Power Op Amps. ____________________________Typical Operating … |
File Format / Size | PDF / 148 Kb |
500MHz, Low-Power Op Amps. ____________________________Typical Operating Characteristics (continued)
500MHz, Low-Power Op Amps ____________________________Typical Operating Characteristics (continued)
(VCC = 5V, VEE = -5V, TA = +25°C, unless otherwise noted.)
MAX4100 OPEN-LOOP GAIN MAX4101 OPEN-LOOP GAIN MAX4100 CLOSED-LOOP RESPONSE AND PHASE vs. FREQUENCY AND PHASE vs. FREQUENCY (AVCL = +1)
3 60 0 60 0 50 50 2 MAX4100-19 MAX4100-18 1 MAX4100 TOC-22 40 45 45 GAIN 40 GAIN 0 30 30 -1 20 90 20 90 -2 PHASE PHASE GAIN (dB) 10 10 -3 LOOP GAIN (dB) PHASE (DEGREES) LOOP GAIN (dB) PHASE (DEGREES) -4 0 135 0 135 -5 -10 -10 -6 -20 180 -20 180 -7
MAX4100/MAX4101
10k 100k 1M 10M 100M 1G 10k 100k 1M 10M 100M 1G 0.1M 1M 10M 100M 1G FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz)
MAX4101 CLOSED-LOOP RESPONSE MAX4100 MAX4100 (AVCL = +2) HARMONIC DISTORTION vs. FREQUENCY HARMONIC DISTORTION vs. FREQUENCY
9 0 0 GAIN = +1 GAIN = +2 8 -10 VO = 2Vp-p -10 VO = 2Vp-p R R 7 MAX4100 TOC-23 L = 100Ω L = 100Ω MAX4100 TOC-24 MAX4100 TOC-25 -20 -20 6 -30 -30 5 -40 -40 4 GAIN (dB) 2nd HARMONIC -50 3 -50 2nd HARMONIC 2 -60 -60 1 -70 -70 HARMONIC DISTORTION (dBc) HARMONIC DISTORTION (dBc) 3rd HARMONIC 3rd HARMONIC 0 -80 -80 -1 -90 -90 0.1M 1M 10M 100M 1G 0.1 1 10 100 0.1 1 10 100 FREQUENCY (Hz) FREQUENCY (MHz) FREQUENCY (MHz)
MAX4100 MAX4101 MAX4101 HARMONIC DISTORTION vs. FREQUENCY HARMONIC DISTORTION vs. FREQUENCY HARMONIC DISTORTION vs. FREQUENCY
0 0 0 GAIN = +5 GAIN = +2 GAIN = +5 -10 VO = 2Vp-p -10 VO = 2Vp-p -10 VO = 2Vp-p RL = 100Ω R R MAX4100 TOC-26 L = 100Ω MAX4100 TOC-27 L = 100Ω MAX4100 TOC-28 -20 -20 -20 -30 -30 -30 -40 -40 -40 -50 -50 -50 2nd HARMONIC 2nd HARMONIC -60 -60 -60 3rd HARMONIC 2nd HARMONIC -70 3rd HARMONIC HARMONIC DISTORTION (dBc) -70 HARMONIC DISTORTION (dBc) -70 HARMONIC DISTORTION (dBc) 3rd HARMONIC -80 -80 -80 -90 -90 -90 0.1 1 10 100 0.1 1 10 100 0.1 1 10 100 FREQUENCY (MHz) FREQUENCY (MHz) FREQUENCY (MHz)
6 _______________________________________________________________________________________
