Datasheet MAX4100, MAX4101 (Maxim) - 7
ManufacturerMaxim
Description500MHz, Low-Power Op Amps
Pages / Page12 / 7 — 500MHz, Low-Power Op Amps. MAX4100/MAX4101. …
File Format / SizePDF / 148 Kb
500MHz, Low-Power Op Amps. MAX4100/MAX4101. ____________________________Typical Operating Characteristics (continued)
500MHz, Low-Power Op Amps MAX4100/MAX4101 ____________________________Typical Operating Characteristics (continued)
(VCC = 5V, VEE = -5V, TA = +25°C, unless otherwise noted.)
MAX4101 TWO-TONE THIRD-ORDER HARMONIC DISTORTION vs. FREQUENCY INTERCEPT vs. FREQUENCY
0 40 GAIN = +10 -10 VO = 2Vp-p 35 MAX4100-30 RL = 100Ω MAX4100 TOC-29 -20 20 -30 25 -40 20 -50 2nd HARMONIC 15 -60 3rd HARMONIC 10 -70 HARMONIC DISTORTION (dBc) THIRD-ORDER INTERCEPT (dBm) 5 -80 -90 0 0.1 1 10 100 0.1 1 10 100 FREQUENCY (MHz) FREQUENCY (MHz)
MAX4100 MAX4101 DIFFERENTIAL GAIN AND PHASE DIFFERENTIAL GAIN AND PHASE
0.02 0.02 -0.00 -0.00 MAX4100-31 -0.02 -0.02 MAX4100-32 -0.04 -0.04 -0.06 DIFF GAIN (%) -0.06 DIFF GAIN (%) -0.08 -0.08 -0.10 0 100 0 100 0.05 0.06 0.04 0.03 0.04 0.02 0.02 0.01 0.00 0.00 -0.01 DIFF PHASE (deg) DIFF PHASE (deg) -0.02 0 100 0 100 IRE IRE
______________________________________________________________Pin Description PIN NAME FUNCTION
1, 5, 8 N.C. No Connection, not internally connected 2 IN- Inverting Input 3 IN+ Noninverting Input 4 VEE Negative Power Supply, connected to -5V 6 OUT Amplifier Output 7 VCC Positive Power Supply, connected to +5V
_______________________________________________________________________________________ 7
