Datasheet 1N4460 - 1N4496, 1N6485 - 1N6491 (Microsemi) - 2
Manufacturer | Microsemi |
Description | VOIDLESS HERMETICALLY SEALED 1.5 WATT GLASS ZENER DIODES |
Pages / Page | 6 / 2 — 1N4460 – 1N4496 and 1N6485 – 1N6491 MECHANICAL and PACKAGING |
File Format / Size | PDF / 424 Kb |
• CASE: Hermetically sealed voidless hard glass with tungsten slugs.
TERMINALS: Tin/lead (Sn/Pb) or RoHS compliant matte/tin (commercial grade only) over copper.
MARKING: Body coated in blue with part number.
POLARITY: Cathode indicated by band.
TAPE & REEL option: Standard per EIA-296. Consult factory for quantities.
WEIGHT: 340 milligrams.
See Package Dimensions on last page. PART NOMENCLATURE JAN 1N4460 C (e3) Reliability Level
JAN = JAN Level
JANTX = JANTX Level
JANTXV = JANTXV Level
JANS = JANS Level
Blank = Commercial RoHS Compliance
e3 = RoHS compliant (available
on commercial grade only)
Blank = non-RoHS compliant
Tolerance Level
Blank = 5 %
C=2%
D = 1% JEDEC type number
(See Electrical Characteristics
table) SYMBOLS & DEFINITIONS
Definition Symbol
VZ
I Z , I ZT , I ZK
Z ZT or Z ZK
VF
IR
I ZM
I ZSM Zener Voltage: The Zener voltage the device will exhibit at a specified current (I Z ) in its breakdown region.
Regulator Current: The dc regulator current (I Z ), at a specified test point (I ZT ), near breakdown knee (I ZK ).
Dynamic Impedance: The small signal impedance of the diode when biased to operate in its breakdown region at a
specified rms current modulation (typically 10% of I ZT or I ZK ) and superimposed on I ZT or I ZK respectively.
Maximum Forward Voltage: The maximum forward voltage the device will exhibit at a specified current.
Maximum Reverse Current: The maximum reverse (leakage) current that will flow at the specified voltage and
temperature.
Maximum Regulator (Zener) Current: The maximum rated dc current for the specified power rating.
Maximum Zener Surge Current: The non-repetitive peak value of Zener surge current at a specified wave form. T4-LDS-0183, Rev. 3 (120901) ©2012 Microsemi Corporation Page 2 of 6
