Datasheet MC10EL31, MC100EL31 (ON Semiconductor) - 3
ManufacturerON Semiconductor
Description5 V ECL D Flip‐Flop with Set and Reset
Pages / Page8 / 3 — MC10EL31, MC100EL31. Table 4. 10EL SERIES PECL DC CHARACTERISTICS. −40. …
Revision8
File Format / SizePDF / 200 Kb
MC10EL31, MC100EL31. Table 4. 10EL SERIES PECL DC CHARACTERISTICS. −40. Symbol. Characteristic. Min. Typ. Max. Unit
MC10EL31, MC100EL31 Table 4 10EL SERIES PECL DC CHARACTERISTICS −40 Symbol Characteristic Min Typ Max Unit
link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3
MC10EL31, MC100EL31 Table 4. 10EL SERIES PECL DC CHARACTERISTICS
(VCC = 5.0 V; VEE = 0 V (Note 1))
−40
C 25
C 85
C Symbol Characteristic Min Typ Max Min Typ Max Min Typ Max Unit
IEE Power Supply Current 27 32 27 32 27 32 mA VOH Output HIGH Voltage (Note 2) 3920 4010 4110 4020 4105 4190 4090 4185 4280 mV VOL Output LOW Voltage (Note 2) 3050 3200 3350 3050 3210 3370 3050 3227 3405 mV VIH Input HIGH Voltage 3770 4110 3870 4190 3940 4280 mV VIL Input LOW Voltage 3050 3500 3050 3520 3050 3555 mV IIH Input HIGH Current 150 150 150 mA IIL Input LOW Current 0.5 0.5 0.3 mA NOTE: Device will meet the specifications after thermal equilibrium has been established when mounted in a test socket or printed circuit board with maintained transverse airflow greater than 500 lfpm. 1. Input and output parameters vary 1:1 with VCC. VEE can vary +0.25 V / −0.5 V. 2. Outputs are terminated through a 50 ohm resistor to VCC−2 volts.
Table 5. 10EL SERIES NECL DC CHARACTERISTICS
(VCC = 0 V; VEE = −5.0 V (Note 1))
−40
C 25
C 85
IEE Power Supply Current 27 32 27 32 27 32 mA VOH Output HIGH Voltage (Note 2) −1080 −990 −890 −980 −895 −810 −910 −815 −720 mV VOL Output LOW Voltage (Note 2) −1950 −1800 −1650 −1950 −1790 −1630 −1950 −1773 −1595 mV VIH Input HIGH Voltage −1230 −890 −1130 −810 −1060 −720 mV VIL Input LOW Voltage −1950 −1500 −1950 −1480 −1950 −1445 mV IIH Input HIGH Current 150 150 150 mA IIL Input LOW Current 0.5 0.5 0.3 mA NOTE: Device will meet the specifications after thermal equilibrium has been established when mounted in a test socket or printed circuit board with maintained transverse airflow greater than 500 lfpm. 1. Input and output parameters vary 1:1 with VCC. VEE can vary +0.25 V / −0.5 V. 2. Outputs are terminated through a 50 ohm resistor to VCC−2 volts.
Table 6. 100EL SERIES PECL DC CHARACTERISTICS
−40
C 25
C 85
IEE Power Supply Current 27 32 27 32 31 37 mA VOH Output HIGH Voltage (Note 2) 3915 3995 4120 3975 4045 4120 3975 4050 4120 mV VOL Output LOW Voltage (Note 2) 3170 3305 3445 3190 3295 3380 3190 3295 3380 mV VIH Input HIGH Voltage 3835 4120 3835 4120 3835 4120 mV VIL Input LOW Voltage 3190 3525 3190 3525 3190 3525 mV IIH Input HIGH Current 150 150 150 mA IIL Input LOW Current 0.5 0.5 0.5 mA NOTE: Device will meet the specifications after thermal equilibrium has been established when mounted in a test socket or printed circuit board with maintained transverse airflow greater than 500 lfpm. 1. Input and output parameters vary 1:1 with VCC. VEE can vary +0.8 V / −0.5 V. 2. Outputs are terminated through a 50 ohm resistor to VCC−2 volts.
www.onsemi.com 3
