Datasheet MAX492, MAX494, MAX495 (Maxim) - 5
ManufacturerMaxim
DescriptionSingle/Dual/Quad, Micropower, Single-Supply, Rail-to-Rail Op Amps
Pages / Page17 / 5 — Single/Dual/Quad, Micropower, Single-Supply Rail-to-Rail Op Amps. DC …
File Format / SizePDF / 247 Kb
Single/Dual/Quad, Micropower, Single-Supply Rail-to-Rail Op Amps. DC ELECTRICAL CHARACTERISTICS. PARAMETER. CONDITIONS. MIN. TYP
Single/Dual/Quad, Micropower, Single-Supply Rail-to-Rail Op Amps DC ELECTRICAL CHARACTERISTICS PARAMETER CONDITIONS MIN TYP
(VCC = 2.7V to 6V, VEE = GND, VCM = 0V, VOUT = VCC / 2, TA = -40°C to +85°C, unless otherwise noted.)
PARAMETER CONDITIONS MIN TYP MAX UNITS
Input Offset Voltage VCM = VEE to VCC ±950 µV Input Offset Voltage Tempco ±2 µV/°C Input Bias Current VCM = VEE to VCC ±100 nA Input Offset Current VCM = VEE to VCC ±8 nA Common-Mode Input VEE - 0.15 VCC + 0.15 V Voltage Range Common-Mode Rejection Ratio (VEE - 0.15) ≤ VCM ≤ (VCC + 0.15) 68 dB Power-Supply Rejection Ratio VCC = 2.7V to 6V, VCM = 0V 84 dB Sourcing 86 VCC = 2.7V, RL = 100kΩ, VOUT = 0.25V to 2.45V Sinking 84 Sourcing 92 VCC = 2.7V, RL = 1kΩ, VOUT = 0.5V to 2.2V Large-Signal Voltage Gain Sinking 76 dB (Note 1) Sourcing 92 VCC = 5.0V, RL = 100kΩ, VOUT = 0.25V to 4.75V Sinking 86 Sourcing 96 VCC = 5.0V, RL = 1kΩ, VOUT = 0.5V to 4.5V Sinking 80
MAX492/MAX494/MAX495
VOH VCC - 0.075 RL = 100kΩ Output Voltage Swing VOL VEE + 0.075 V (Note 1) VOH VCC - 0.20 RL = 1kΩ VOL VEE + 0.20 Operating Supply-Voltage Range 2.7 6.0 V VCC = 2.7V 185 Supply Current (per amplifier) VCM = VOUT = VCC / 2 µA VCC = 5V 200
4 _______________________________________________________________________________________
Document Outline not-recomm-data-sheet-coverMAX495.pdf Not Recommended for New Designs
