Datasheet MAX492, MAX494, MAX495 (Maxim) - 6
ManufacturerMaxim
DescriptionSingle/Dual/Quad, Micropower, Single-Supply, Rail-to-Rail Op Amps
Pages / Page17 / 6 — Single/Dual/Quad, Micropower,. Single-Supply Rail-to-Rail Op Amps. …
File Format / SizePDF / 247 Kb
Single/Dual/Quad, Micropower,. Single-Supply Rail-to-Rail Op Amps. MAX492/MAX494/MAX495. DC ELECTRICAL CHARACTERISTICS
Single/Dual/Quad, Micropower, Single-Supply Rail-to-Rail Op Amps MAX492/MAX494/MAX495 DC ELECTRICAL CHARACTERISTICS
(VCC = 2.7V to 6V, VEE = GND, VCM = 0V, VOUT = VCC / 2, TA = -55°C to +125°C, unless otherwise noted.)
PARAMETER CONDITIONS MIN TYP MAX UNITS
Input Offset Voltage VCM = VEE to VCC ±1.2 mV Input Offset Voltage Tempco ±2 µV/°C Input Bias Current VCM = VEE to VCC ±200 nA Input Offset Current VCM = VEE to VCC ±10 nA Common-Mode Input Voltage Range VEE - 0.05 VCC + 0.05 V Common-Mode Rejection Ratio (VEE - 0.05V) ≤ VCM ≤ (VCC + 0.05V) 66 dB Power-Supply Rejection Ratio VCC = 2.7V to 6V 80 dB VCC = 2.7V, RL = 100kΩ, Sourcing 82 VOUT = 0.25V to 2.45V Sinking 80 VCC = 2.7V, RL = 1kΩ, Sourcing 90 VOUT = 0.5V to 2.2V Large-Signal Voltage Gain Sinking 72 dB (Note 1) VCC = 5.0V, RL = 100kΩ, Sourcing 86 VOUT = 0.25V to 4.75V Sinking 82 VCC = 5.0V, RL = 1kΩ, Sourcing 94 VOUT = 0.5V to 4.5V Sinking 76 VOH VCC - 0.075 RL = 100kΩ Output Voltage Swing VOL VEE + 0.075 V (Note 1) VOH VCC - 0.250 RL = 1kΩ VOL VEE + 0.250 Operating Supply-Voltage Range 2.7 6.0 V VCC = 2.7V 200 Supply Current (per amplifier) VCM = VOUT = VCC / 2 µA VCC = 5V 225
Note 1:
RL to VEE for sourcing and VOH tests; RL to VCC for sinking and VOL tests.
_______________________________________________________________________________________ 5
Document Outline not-recomm-data-sheet-coverMAX495.pdf Not Recommended for New Designs
