Datasheet MAX492, MAX494, MAX495 (Maxim) - 7
Manufacturer | Maxim |
Description | Single/Dual/Quad, Micropower, Single-Supply, Rail-to-Rail Op Amps |
Pages / Page | 17 / 7 — Single/Dual/Quad, Micropower, Single-Supply Rail-to-Rail Op Amps |
File Format / Size | PDF / 247 Kb |
Single/Dual/Quad, Micropower, Single-Supply Rail-to-Rail Op Amps __________________________________________Typical Operating Characteristics
(TA = +25°C, VCC = 5V, VEE = 0V, unless otherwise noted.)
GAIN AND PHASE GAIN AND PHASE POWER-SUPPLY REJECTION RATIO vs. FREQUENCY vs. FREQUENCY vs. FREQUENCY
MAX492-01 80 180 MAX492-02 80 180 140 120 MAX492-03 60 120 60 120 GAIN GAIN 100 VCC 40 60 40 60 80 20 PHASE 0 20 0 60 GAIN (dB) PHASE PHASE (DEG) GAIN (dB) PHASE (DEG) PSRR (dB) 40 VEE 0 -60 0 -60 20 -20 -120 -20 CL = 470pF -120 AV = +1000 AV = +1000 0 NO LOAD RL = ∞ VIN = 2.5V -40 -180 -40 -180 -20 0.01 0.1 1 10 100 1000 10,000 0.01 0.1 1 10 100 1000 10,000 0.01 0.1 1 10 100 1000 FREQUENCY (kHz) FREQUENCY (kHz) FREQUENCY (kHz)
CHANNEL SEPARATION OFFSET VOLTAGE COMMON-MODE REJECTION RATIO vs. FREQUENCY vs. TEMPERATURE vs. TEMPERATURE
140 160 120
MAX492/MAX494/MAX495
VCM = 0V V MAX492-04 CM = 0V TO +5V 120 140 MAX492-05 MAX492-06 110 VCM = -01V TO +5.1V 120 100 µV) 100 100 80 80 90 60 60 CMRR (dB) 80 V 40 CM = -0.2V TO +5.2V OFFSET VOLTAGE ( 40 CHANNEL SEPARATION (dB) VCM = -0.3V TO +5.3V 20 70 20 VCM = -0.4V TO +5.4V VIN = 2.5V 0 0 60 0.01 0.1 1 10 100 1000 10,000 -60 -40 -20 0 20 40 60 80 100 120 140 -60 -40 -20 0 20 40 60 80 100 120 140 FREQUENCY (kHz) TEMPERATURE (°C) TEMPERATURE (°C)
INPUT BIAS CURRENT INPUT BIAS CURRENT SUPPLY CURRENT PER AMPLIFIER vs. COMMON-MODE VOLTAGE vs. TEMPERATURE vs. TEMPERATURE
20 125 220 15 100 200 VOUT = VCM = VCC/2 MAX492-07 VCC = 2.7V MAX492-08 MAX492-09 µA) VCC = 6V 10 75 180 VCC = 6V 5 50 160 VCC = 5V 0 25 VCM = VCC 140 VCC = 2.7V 120 -5 0 VCC = 2.7V 100 -10 -25 80 -15 -50 VCM = 0 60 INPUT BIAS CURRENT (nA) -20 INPUT BIAS CURRENT (nA) -75 40 -25 -100 SUPPLY CURRENT PER OP AMP ( 20 VCC = 6V -30 -125 0 0 1 2 3 4 5 6 7 -60 -40 -20 0 20 40 60 80 100 120 140 -60 -40 -20 0 20 40 60 80 100 120 140 VCM (V) TEMPERATURE (°C) TEMPERATURE (°C)
6 _______________________________________________________________________________________
Document Outline not-recomm-data-sheet-coverMAX495.pdf Not Recommended for New Designs
