Datasheet MAX492, MAX494, MAX495 (Maxim) - 8
Manufacturer | Maxim |
Description | Single/Dual/Quad, Micropower, Single-Supply, Rail-to-Rail Op Amps |
Pages / Page | 17 / 8 — Single/Dual/Quad, Micropower,. Single-Supply Rail-to-Rail Op Amps. … |
File Format / Size | PDF / 247 Kb |
Single/Dual/Quad, Micropower,. Single-Supply Rail-to-Rail Op Amps. MAX492/MAX494/MAX495
Single/Dual/Quad, Micropower, Single-Supply Rail-to-Rail Op Amps MAX492/MAX494/MAX495 ____________________________Typical Operating Characteristics (continued)
(TA = +25°C, VCC = 5V, VEE = 0V, unless otherwise noted.)
LARGE-SIGNAL GAIN LARGE-SIGNAL GAIN LARGE-SIGNAL GAIN vs. OUTPUT VOLTAGE vs. OUTPUT VOLTAGE vs. TEMPERATURE
120 120 120 RL = 10kΩ RL = 1MΩ RL = 1kΩ, 0.5V < VOUT < (VCC - 0.5V) 110 MAX492-10 110 MAX492-11 115 MAX492-12 RL TO VCC 110 100 RL = 1MΩ 100 105 90 RL = 100kΩ 90 RL = 100kΩ R 100 GAIN (dB) RL = 1kΩ L = 10kΩ 80 GAIN (dB) 80 RL = 1kΩ 95 VCC = +2.7V V 70 70 CC = +6V 90 LARGE-SIGNAL GAIN (dB) RL TO VEE 60 VCC = +6V 60 VCC = +2.7V 85 RL TO VEE RL TO VEE 50 50 80 0 100 200 300 400 500 600 0 100 200 300 400 500 600 -60 -40 -20 0 20 40 60 80 100 120 140 VCC - VOUT (mV) VCC - VOUT (mV) TEMPERATURE (°C)
120 120 120 R RL = 100kΩ, 0.3V < VOUT < (VCC - 0.3V) L = 1MΩ 110 MAX492-13 R 115 110 L = 1MΩ MAX492-14 MAX492-15 R R L TO VCC R L = 100kΩ L = 100kΩ 110 VCC = +6V 100 100 105 90 90 RL = 1kΩ 100 GAIN (dB) 80 R GAIN (dB) L = 10kΩ 80 RL = 1kΩ 95 R R 70 L = 10kΩ L TO VEE 70 90 LARGE-SIGNAL GAIN (dB) VCC = +2.7V 60 VCC = +6V 60 VCC = +2.7V 85 RL TO VCC RL TO VCC 50 50 80 0 100 200 300 400 500 600 0 100 200 300 400 500 600 -60 -40 -20 0 20 40 60 80 100 120 140 VOUT (mV) VOUT (mV) TEMPERATURE (°C)
MINIMUM OUTPUT VOLTAGE MAXIMUM OUTPUT VOLTAGE OUTPUT IMPEDANCE vs. TEMPERATURE vs. TEMPERATURE vs. FREQUENCY
220 200 1000 200 RL TO VCC 180 RL TO VEE VCM = VOUT = 2.5V MAX492-16 MAX492-17 MAX492-18 180 VCC = 6V, RL = 1kΩ 160 V ) CC = 6V, RL = 1kΩ 160 Ω 100 140 VCC = 2.7V, RL = 1kΩ 140 ) (mV) 120 120 VCC = 2.7V, RL = 1kΩ OUT 100 MIN (mV) 10 100 - V OUT 80 V 80 CC(V 60 60 VCC = 6V, RL = 100kΩ VCC = 6V, RL = 100kΩ V OUTPUT IMPEDANCE ( 1 40 40 CC = 2.7V, RL = 100kΩ 20 VCC = 2.7V, RL = 100kΩ 20 0 0 0.1 -60 -40 -20 0 20 40 60 80 100 120 140 -60 -40 -20 0 20 40 60 80 100 120 140 0.01 0.1 1 10 100 1,000 10,000 TEMPERATURE (°C) TEMPERATURE (°C) FREQUENCY (kHz)
_______________________________________________________________________________________ 7
Document Outline not-recomm-data-sheet-coverMAX495.pdf Not Recommended for New Designs
