Datasheet MAX492, MAX494, MAX495 (Maxim) - 9
ManufacturerMaxim
DescriptionSingle/Dual/Quad, Micropower, Single-Supply, Rail-to-Rail Op Amps
Pages / Page17 / 9 — Single/Dual/Quad, Micropower, Single-Supply Rail-to-Rail Op Amps
File Format / SizePDF / 247 Kb
Single/Dual/Quad, Micropower, Single-Supply Rail-to-Rail Op Amps ____________________________Typical Operating Characteristics (continued)
(TA = +25°C, VCC = 5V, VEE = 0V, unless otherwise noted.)
VOLTAGE-NOISE DENSITY CURRENT-NOISE DENSITY vs. FREQUENCY vs. FREQUENCY
100 5.0 4.5 MAX492-19 MAX492-20 √Hz) √Hz) 4.0 3.5 3.0 2.5 10 2.0 1.5 1.0 VOLTAGE-NOISE DENSITY (nV/ INPUT REFERRED CURRENT-NOISE DENSITY (pA/ INPUT REFERRED 0.5 1 0 0.01 0.1 1 10 0.01 0.1 1 10 FREQUENCY (kHz) FREQUENCY (kHz)
TOTAL HARMONIC DISTORTION + NOISE TOTAL HARMONIC DISTORTION + NOISE vs. FREQUENCY vs. PEAK-TO-PEAK SIGNAL AMPLITUDE
0.1 0.1 A
MAX492/MAX494/MAX495
AV = +1 V = +1 MAX492-22 1kHz SINE MAX492-21 2VP-P SIGNAL 80kHz LOWPASS FILTER 22kHz FILTER RL TO GND RL = 1kΩ RL = 2kΩ 0.01 0.01 RL = 10kΩ TO GND THD + NOISE (%) THD + NOISE (%) RL = 100kΩ RL = 10kΩ NO LOAD 0.001 0.001 4.0 4.1 4.2 4.3 4.4 4.5 4.6 4.7 4.8 4.9 5.0 10 100 1000 10,000 PEAK-TO-PEAK SIGNAL AMPLITUDE (V) FREQUENCY (Hz)
SMALL-SIGNAL TRANSIENT RESPONSE SMALL-SIGNAL TRANSIENT RESPONSE
VIN VIN 50mV/div 50mV/div VOUT VOUT 50mV/div 50mV/div 2µs/div 2µs/div VCC = +5V, AV = +1, RL = 10kΩ VCC = +5V, AV = -1, RL = 10kΩ
8 _______________________________________________________________________________________
Document Outline not-recomm-data-sheet-coverMAX495.pdf Not Recommended for New Designs
