Datasheet IL4216, IL4217, IL4218 (Vishay) - 2
ManufacturerVishay
DescriptionOptocoupler, Phototriac Output, High dV/dt, Low Input Current
Pages / Page6 / 2 — IL4216, IL4217, IL4218. ABSOLUTE MAXIMUM RATINGS (1). PARAMETER. TEST …
File Format / SizePDF / 125 Kb
IL4216, IL4217, IL4218. ABSOLUTE MAXIMUM RATINGS (1). PARAMETER. TEST CONDITION. PART. SYMBOL. VALUE. UNIT. INPUT. OUTPUT. COUPLER. Notes
IL4216, IL4217, IL4218 ABSOLUTE MAXIMUM RATINGS (1) PARAMETER TEST CONDITION PART SYMBOL VALUE UNIT INPUT OUTPUT COUPLER Notes
Vishay Semiconductors Optocoupler, Phototriac Output, High dV/dt, Low Input Current
(Tamb = 25 °C, unless otherwise specified)
Reverse voltage VR 6 V Forward current IF 60 mA Surge current IFSM 2.5 A Power dissipation Pdiss 100 mW Derate linearly from 25 °C 1.33 mW/°C Thermal resistance Rth 750 °C/W
OUTPUT
IL4216 VDRM 600 V Peak off-state voltage IL4217 VDRM 700 V IL4218 VDRM 800 V RMS on-state current IDRM 300 mA Single cycle surge ITSM 3 A Power dissipation Pdiss 300 mW Derate linearly from 25 °C 6.6 mW/°C Thermal resistance Rth 150 °C/W
COUPLER
Creepage distance ≥ 7 mm Clearance ≥ 7 mm Storage temperature Tstg - 55 to + 150 °C Ambient temperature Tamb - 55 to + 100 °C Isolation test voltage VISO 5300 VRMS VIO = 500 V, Tamb = 25 °C RIO ≥ 1012 Ω Isolation resistance VIO = 500 V, Tamb = 100 °C RIO ≥ 1011 Ω Lead soldering temperature (2) 5 s Tsld 260 °C
Notes
(1) Stresses in excess of the absolute maximum ratings can cause permanent damage to the device. Functional operation of the device is not implied at these or any other conditions in excess of those given in the operational sections of this document. Exposure to absolute maximum ratings for extended periods of the time can adversely affect reliability. (2) Refer to reflow profile for soldering conditions for surface mounted devices (SMD). Refer to wave profile for soldering conditions for through hole devices (DIP). www.vishay.com For technical questions, contact: optocoupleranswers@vishay.com Document Number: 83630 2 Rev. 1.6, 20-Oct-10
