CBRSDSH2-40SURFACE MOUNTwww.centra lsemi.com2 AMP SILICONDESCRIPTION:SCHOTTKY BRIDGE RECTIFIER The CENTRAL SEMICONDUCTOR CBRSDSH2-40 is a full wave bridge rectifier mounted in a durable epoxy surface mount case, utilizing glass passivated chips. MARKING: FULL PART NUMBERFEATURES:• Low Leakage Current (40µA TYP @ VRRM) • High 2.0A Current Rating SMDIP CASE• Low VF Schottky Diodes (400mV TYP @ IF=2.0A) MAXIMUM RATINGS: (TA=25°C) SYMBOLUNITS Peak Repetitive Reverse Voltage VRRM 40 V DC Blocking Voltage VR 40 V RMS Reverse Voltage VR(RMS) 28 V Average Forward Current IO 2.0 A Peak Forward Surge Current (8.3ms) IFSM 110 A Operating and Storage Junction Temperature TJ, Tstg -50 to +125 °C Typical Thermal Resistance (Note 1) ΘJA 40 °C/W Typical Thermal Resistance ΘJL 15 °C/W ELECTRICAL CHARACTERISTICS PER DIODE: (TA=25°C unless otherwise noted) SYMBOL TESTCONDITIONSTYPMAXUNITS IR VR=40V 40 70 µA VF IF=2.0A 400 450 mV CJ VR=4.0V, f=1.0MHz 400 500 pF Notes: (1) Devices mounted on PCB with 13mm x 13mm copper pads. R1 (26-October 2011)
