Datasheet CPD73 (Central Semiconductor) - 7
Manufacturer | Central Semiconductor |
Description | Bridge Rectifier Monolithic Quad Diode Bridge Chip |
Pages / Page | 9 / 7 — http://www.centralsemi.com. * All Plating types (PBFREE,TIN/LEAD) for … |
File Format / Size | PDF / 709 Kb |
http://www.centralsemi.com. * All Plating types (PBFREE,TIN/LEAD) for each item listed are included in this notice
PDN00999 8/03/15 Varies
Varies *** CONTINUED FROM PRIOR PAGE ***
* All Plating types (PBFREE,TIN/LEAD) for each item listed are included in this notice. Central Part Number Replacement
CP188-BC237B-CT N/A, Stock Only CP188-CMPT5089-CT CP388X-2N5089-CT CP188-CMPT5089-WN N/A, Stock Only CP188-2N2484-CT CP388X-2N2484-CT CP188-2N2484-WN CP388X-2N2484-WN CP188-2N2920-CTJ N/A, Stock Only CP188-2N5088-CTO CP388X-2N5088-CT CP188V-BCX70K-WR CP388X-BCX70K-WR CP188V-2N5088-CT CP388X-2N5088-CT CP191-2N2219A-CT N/A, Stock Only CP191-2N2222A-CT CP191V-2N2222A-CT CP191-2N2222A-WN CP191V-2N2222A-WN CP191-2N2222A-WR CP191V-2N2222A-WR CP191-2N2222A-WS CP191V-2N2222A-WR CP195-2N3501-CT CP318V-2N3501-CT CP195-2N3501-WN CP318V-2N3501-WN CP195-2N5682-CT CP318V-2N5682-CT CP195-2N5682-WN CP318V-2N5682-WN CP207-2N2369A-CT CP396V-2N2369A-CT CP207-2N2369A-WN CP396V-2N2369A-WN CP237-2N3725-CT CP337V-2N3725-WN CP301-2N3439-CT CP310-2N3439-CT CP303V-CMPT8099-CT CP303X-CMPT8099-CT CP303V-CMPT8099-WN CP303X-CMPT8099-WN CP305-MJE182-CT CP325V-MJE182-CT CP314-MPS650-CT CP314V-MPS650-CT CP316-2N5551-CT CP336V-2N5551-CT CP316V-2N5551-CT CP336V-2N5551-CT CP316V-2N5551-CTAN N/A, Stock Only CP316V-2N5551-WN CP336V-2N5551-WN CP317-2N2857-CT N/A, Stock Only CP317-2N918-CT N/A, Stock Only CP319-CZTA44HC-CT CP212-CZTA44HC-CT CP319-TIP47-CT CP212-TIP47-CT CP319-TIP50-CT CP212-TIP50-CT CP324-2N7002-CM N/A, Stock Only CP324-2N7002-CT N/A, Stock Only CP324-2N7002-WN N/A, Stock Only CP336V-2N5551-CTAN CP336V-2N5551-CT CP353-2N3506-CT CP353V-2N3506-CT CP512-2N4033-CT CP705V-CZT4033-CT CP512-2N4033-WN CP705V-CZT4033-WN CP517-BDX54C-WS CP527-BDX54C-WR *** CONTINUED ***
