Preliminary Datasheet EPC23101 (Efficient Power Conversion) - 9
Manufacturer | Efficient Power Conversion |
Description | ePower Chipset 100 V, 65 A |
Pages / Page | 9 / 9 — eGaN® FET DATASHEET. Pads 1-8,13 and 14 are IC pins. EPC. 23101. Pads 9 … |
File Format / Size | PDF / 983 Kb |
eGaN® FET DATASHEET. Pads 1-8,13 and 14 are IC pins. EPC. 23101. Pads 9 and 11 are SW. XYYWW. pins. XXXX. Pads 10 and 12 are VIN pins
filename ../../../../AppData/Local/Adobe/InDesign/Version 17.0/en_US/Caches/InDesign ClipboardScrap1.pdf
eGaN® FET DATASHEET
EPC23101 13 14 12 11 10 1 2 9 3
EPC
8 4
23101
7 5
Pads 9 and 11 are SW XYYWW
6
pins
XXXX Pads 10 and 12 are VIN pins
Site/date code 0.10 Max. Lot code // ccc C C
A
7 eee C
A1 A1
Seating plane 0.05
D A A3
2.600 Max.
Side View 2
Die size
B 12 K1
(3x)
11 E e1 Exposed 10 die
4.470 5.00
K
(3x) Die size
9 L
2x
13 e
C
8 14
aaa
7 K
(2x)
A3 6 5 4 3 2 1
6
b (14)
aaa C 2x
A
bbb M C
b1
(2x) A B ddd M C
Top View Side View 1 Bottom View Notes: Dimension (mm) Dimension (mm) SYMBOL SYMBOL
1. Dimensioning and tolerancing conform to
MIN Nominal MAX Note MIN Nominal MAX Note
ASME Y14.5-2009
A
0.60 0.65 0.70
L
0.30 0.40 0.50
A1
0.00 0.02 0.05
aaa
0.05 2. All dimensions are in millimeters
A3
0.20 Ref
bbb
0.10 3.
N
is the total number of terminals
b
0.20 0.25 0.30 6
ccc
0.10 4. Dimension
b
applies to the metallized terminal. If the
b1
0.15 0.20 0.25 6
ddd
0.05 terminal has a radius on the other end of it, dimension
b D
3.50 BSC
eee
0.08 should not be measured in that radius area.
E
5.00 BSC
N
14 3
e
0.50 BSC
ND
6 5 5.
ND
and
NE
refer to the number of terminals on each
D
and E side respectively.
e1
0.85 BSC
NE
7 5
K
0.55 0.60 0.65
Notes
1, 2 6. Dimension
b
applies to the metallized terminal and is mea-
K1
0.15 0.20 0.25 sured between 0.15 mm and 0.30 mm from the terminal tip. If the terminal has a radius on the other end of it, dimension
b
should not be measured in that radius area. 7. Coplanarity applies to the terminals and all the other bottom surface metallization. Efficient Power Conversion Corporation (EPC) reserves the right to make changes without further notice to any products herein to improve reliability, function or design. EPC does not assume any liability arising out of the application or use of any product or circuit described herein; neither does it convey any license under its patent rights, nor the rights of others. Information subject to change without notice. eGaN® is a registered trademark of Efficient Power Conversion Corporation. EPC Patent Listing: epc-co.com/epc/AboutEPC/Patents.aspx Revision 1, December, 2021 EPC – POWER CONVERSION TECHNOLOGY LEADER | EPC-CO.COM | ©2021 | | 9
