Datasheet MAX9140, MAX9141, MAX9142, MAX9144 (Maxim) - 6
ManufacturerMaxim
Description40ns, Low-Power, 3V/5V, Rail-to-Rail Single-Supply Comparators
Pages / Page11 / 6 — Typical Operating Characteristics (continued). PROPAGATION DELAY (tPD-). …
Typical Operating Characteristics (continued). PROPAGATION DELAY (tPD-). PROPAGATION DELAY (tPD+). SINUSOID RESPONSE AT 4MHz
Typical Operating Characteristics (continued) PROPAGATION DELAY (tPD-) PROPAGATION DELAY (tPD+) SINUSOID RESPONSE AT 4MHz
MAX9140/MAX9141/ 40ns, Low-Power, 3V/5V, Rail-to-Rail MAX9142/MAX9144 Single-Supply Comparators
(VCC = 3.0V, VCM = 0V, CL = 15pF, VOD = 10mV, TA = +25°C, unless otherwise noted.)
VOD = 10mV VCC = 5.5V VOD = 10mV VCC = 5.5V VCC = 5.5V INPUT MAX9140TOC13 INPUT MAX9140TOC14 INPUT MAX9140TOC15 50mV/div 50mV/div 50mV/div OUTPUT OUTPUT OUTPUT 2V/div 2V/div 2V/div 10ns/div 10ns/div 50ns/div
Pin Description PIN NAME FUNCTION MAX9140 MAX9141 MAX9142 MAX9144
— — 1 1 OUTA Comparator A Output — — 2 2 INA- Comparator A Inverting Input — — 3 3 INA+ Comparator A Noninverting Input 5 1 8 4 VCC Positive Supply — — 5 5 INB+ Comparator B Noninverting Input — — 6 6 INB- Comparator B Inverting Input — — 7 7 OUTB Comparator B Output — — — 8 OUTC Comparator C Output — — — 9 INC- Comparator C Inverting Input — — — 10 INC+ Comparator C Noninverting Input 2 4 4 11 GND Ground — — — 12 IND+ Comparator D Noninverting Input — — — 13 IND- Comparator D Inverting Input — — — 14 OUTD Comparator D Output 3 2 — — IN+ Noninverting Input 4 3 — — IN- Inverting Input — 6 — — SHDN Shutdown: MAX9141 is active when SHDN is driven high; MAX9141 is in shutdown when SHDN is driven low. — 5 — — LE The output is latched when LE is low. The latch is transparent when LE is high. 1 7 — — OUT Comparator Output — 8 — — N.C. No Connection. Not internally connected. www.maximintegrated.com Maxim Integrated │ 6
