Datasheet PDTC143Z (Nexperia) - 3
Manufacturer | Nexperia |
Description | NPN resistor-equipped transistors; R1 = 4.7 kΩ, R2 = 47 kΩ |
Pages / Page | 17 / 3 — Nexperia. PDTC143Z series. NPN resistor-equipped transistors; R1 = 4.7 k. … |
Revision | 07082018 |
File Format / Size | PDF / 1.6 Mb |
Nexperia. PDTC143Z series. NPN resistor-equipped transistors; R1 = 4.7 k. , R2 = 47 k. 5. Limiting. values. Table 6. Limiting values
link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3
Nexperia PDTC143Z series NPN resistor-equipped transistors; R1 = 4.7 k , R2 = 47 k 5. Limiting values Table 6. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol Parameter Conditions Min Max Unit
VCBO collector-base voltage open emitter - 50 V VCEO collector-emitter voltage open base - 50 V VEBO emitter-base voltage open collector - 5 V VI input voltage positive - +30 V negative - 5 V IO output current - 100 mA ICM peak collector current single pulse; - 100 mA t p 1 ms P tot total power dissipation Tamb 25 C PDTC143ZE (SOT416) [1][2] - 150 mW PDTC143ZM (SOT883) [2][3] - 250 mW PDTC143ZT (SOT23) [1] - 250 mW PDTC143ZU (SOT323) [1] - 200 mW Tj junction temperature - 150 C Tamb ambient temperature 65 +150 C Tstg storage temperature 65 +150 C [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. [2] Reflow soldering is the only recommended soldering method. [3] Device mounted on an FR4 PCB with 70 m copper strip line, standard footprint. PDTC143Z_SER All information provided in this document is subject to legal disclaimers. © Nexperia B.V. 2017. All rights reserved
Product data sheet Rev. 8 — 5 December 2011 3 of 17
Document Outline 1. Product profile 1.1 General description 1.2 Features and benefits 1.3 Applications 1.4 Quick reference data 2. Pinning information 3. Ordering information 4. Marking 5. Limiting values 6. Thermal characteristics 7. Characteristics 8. Test information 8.1 Quality information 9. Package outline 10. Packing information 11. Soldering 12. Revision history 13. Legal information 13.1 Data sheet status 13.2 Definitions 13.3 Disclaimers 13.4 Trademarks 14. Contact information 15. Contents
