Datasheet STGAP2HD (STMicroelectronics)
DescriptionGalvanically isolated 4 A dual gate driver
Pages / Page23 / 1 — STGAP2HD. Features. Application. Product status link. Product label. …
File Format / SizePDF / 815 Kb
STGAP2HD. Features. Application. Product status link. Product label. Description. DS13652. Rev 1. October 2021
Datasheet STGAP2HD STMicroelectronics
STGAP2HD
Datasheet Galvanically isolated 4 A dual gate driver
Features
• High voltage rail up to 1200 V • Driver current capability: 4 A sink/source @ 25 °C • dV/dt transient immunity ±100 V/ns • Overall input-output propagation delay: 75 ns • Separate sink and source option for easy gate driving configuration • 4 A Miller CLAMP • UVLO function • Configurable interlocking function • Dedicated SD and BRAKE pins • Gate driving voltage up to 26 V • 3.3 V, 5 V TTL/CMOS inputs with hysteresis • Temperature shutdown protection • Standby function • 6 kV galvanic isolation • Wide Body SO-36W
Application
• Motor driver for industrial drives, factory automation, home appliances and fans • 600/1200 V inverters • Battery chargers
Product status link
• Induction heating STGAP2HD • Welding
Product label
• UPS • Power supply units • DC-DC converters • Power Factor Correction
The STGAP2HD is a dual gate driver which provides galvanic isolation between each gate driving channel and the low voltage control and interface circuitry. The gate driver is characterized by 4 A current capability and rail-to-rail outputs, making it suitable for mid and high power applications such as power conversion and industrial motor driver inverters. The separated output pins allow to independently optimize turn-on and turn-off by using dedicated gate resistors, while the Miller CLAMP function allows avoiding gate spikes during fast commutations in half-bridge topologies. The device integrates protection functions: dedicated SD and BRAKE pins are available, UVLO and thermal shutdown are included to easily design high reliability systems. In half-bridge topologies the interlocking function prevents outputs from being high at the same time, avoiding shoot-through conditions in case of wrong logic input commands. The interlocking function can be disabled by a dedicated configuration pin, so to allow independent and parallel operation of the two channels. The input to output propagation delay results are contained within 75 ns, providing high PWM control accuracy. A standby mode is available in order to reduce idle power consumption.
DS13652
Rev 1
October 2021
www.st.com For further information contact your local STMicroelectronics sales office. Document Outline Cover image Product status link / summary Features Application Description 1 Block diagram 2 Pin description and connection diagram 3 Electrical data 3.1 Absolute maximum ratings 3.2 Thermal data 3.3 Recommended operating conditions 4 Electrical characteristics 5 Isolation 6 Functional description 6.1 Gate driving power supply and UVLO 6.2 Power-up, power-down and ‘safe state’ 6.3 Control Inputs 6.4 Watchdog 6.5 Thermal shutdown protection 6.6 Standby function 6.7 Interlocking function 7 Typical application diagram 8 Layout 8.1 Layout guidelines and considerations 8.2 Layout example 9 Testing and characterization information 10 Package information 10.1 SO-36W package information 11 Suggested land pattern 12 Ordering information Revision history Contents List of tables List of figures
