Datasheet ESDAxxSCx (STMicroelectronics)
DescriptionQuad Transil array for ESD protection
Pages / Page9 / 1 — ESDAxxSCx. Datasheet. production data. Description. SOT23-5L (SC-59). …
File Format / SizePDF / 313 Kb
ESDAxxSCx. Datasheet. production data. Description. SOT23-5L (SC-59). SOT23-6L (SC-59). ESDAxxSC5. ESDAxxSC6
Datasheet ESDAxxSCx STMicroelectronics
ESDAxxSCx
Quad Transil™ array for ESD protection
Datasheet
production data Description
The ESDAxxSC5 and ESDAxxSC6 are monolithic voltage suppressors designed to protect components which are connected to data and transmission lines against ESD.
SOT23-5L (SC-59) SOT23-6L (SC-59)
They clamp the voltage just above the logic level
ESDAxxSC5 ESDAxxSC6
supply for positive transients, and to a diode drop below ground for negative transient.
Figure 1. ESDAxxSC5 functional diagram Features
1 • 5 4 unidirectional ESD protection • 400 W peak pulse power (8/20 µs) 2 • Benefits 3 4 – High ESD protection level: up to 30 kV – High integration – Suitable for high density boards
Figure 2. ESDAxxSC6 functional diagram
• Complies with the following standards 1 6 – IEC 61000-4-2 level exceed level 4: – 30 kV (air discharge) 2 5 – 30 kV (contact discharge) • MIL STD 883E- Method 3015-7: class3B 3 4 – human body model
Applications Table 1. Device summary Order code VBR min. Package
Where transient overvoltage protection in ESD sensitive equipment is required, such as: ESDA5V3SC5 5.3 V SOT23-5L • Computers ESDA5V3SC6 5.3 V SOT23-6L • Printers ESDA6V1SC5 6.1 V SOT23-5L • Communication systems ESDA6V1SC6 6.1 V SOT23-6L • Cellular phone handsets and accessories ESDA14V2SC5 14.2 V SOT23-5L • Other telephone set ESDA14V2SC6 14.2 V SOT23-6L • Set top boxes ESDA19SC6 19 V SOT23-6L ESDA25SC6 25 V SOT23-6L TM: Transil is a trademark of STMicroelectronics. August 2015 DocID7056 Rev 10 1/9 This is information on a product in full production. www.st.com Document Outline Figure 1. ESDAxxSC5 functional diagram Figure 2. ESDAxxSC6 functional diagram Table 1. Device summary 1 Characteristics Table 2. Absolute ratings (Tamb = 25 °C) Table 3. Electrical characteristics - definitions (Tamb = 25 °C) Table 4. Electrical characteristics - values (Tamb = 25 °C) Figure 3. Peak power dissipation versus initial junction temperature Figure 4. Peak pulse power versus exponential pulse duration (Tj initial = 25 °C) Figure 5. Clamping voltage versus peak pulse current (Tj initial = 25 °C). Rectangular waveform tp = 2.5 µs Figure 6. Capacitance versus reverse applied voltage Figure 7. Relative variation of leakage current versus junction temperature Figure 8. Peak forward voltage drop versus peak forward current 2 Ordering information Figure 9. Ordering information scheme 3 Package information Table 5. SOT23-5L dimensions Figure 10. SOT23-5L footprint (dimensions in mm) Table 6. SOT23-6L dimensions Figure 11. SOT23-6L footprint (dimensions in mm) 4 Ordering information Table 7. Ordering information 5 Revision history Table 8. Document revision history
