Datasheet CMPZ5253B (Central Semiconductor) - 2
Manufacturer | Central Semiconductor |
Description | SURFACE MOUNT SILICON ZENER DIODE 350mW, 5% TOLERANCE |
Pages / Page | 3 / 2 — CMPZ5221B THRU CMPZ5267B. SURFACE MOUNT. SILICON ZENER DIODE. 350mW, 5% … |
File Format / Size | PDF / 483 Kb |
CMPZ5221B THRU CMPZ5267B. SURFACE MOUNT. SILICON ZENER DIODE. 350mW, 5% TOLERANCE. ELECTRICAL CHARACTERISTICS - Continued:
CMPZ5221B THRU CMPZ5267B SURFACE MOUNT SILICON ZENER DIODE 350mW, 5% TOLERANCE ELECTRICAL CHARACTERISTICS - Continued:
(TA=25°C) VF=0.9V MAX @ IF=10mA (for all types)
MAXIMUM MAX. ZENER VOLTAGE TEST MAXIMUM REVERSE TEMP. CURRENT ZENER IMPEDANCE CURRENT COEFF. MARK. TYPE VZ @ IZT CODE MIN NOM MAX IZT ZZT @ IZT ZZT @ IZK IR @ VR
Θ
VZ V V V mA Ω Ω mA μA V % /°C
CMPZ5245B 14.25 15 15.75 8.5 16 600 0.25 0.1 11 +0.082 C8V CMPZ5246B 15.20 16 16.80 7.8 17 600 0.25 0.1 12 +0.083 C8W CMPZ5247B 16.15 17 17.85 7.4 19 600 0.25 0.1 13 +0.084 C8X CMPZ5248B 17.10 18 18.90 7.0 21 600 0.25 0.1 14 +0.085 C8Y CMPZ5249B 18.05 19 19.95 6.6 23 600 0.25 0.1 14 +0.086 C8Z CMPZ5250B 19.00 20 21.00 6.2 25 600 0.25 0.1 15 +0.086 81A CMPZ5251B 20.90 22 23.10 5.6 29 600 0.25 0.1 17 +0.087 81B CMPZ5252B 22.80 24 25.20 5.2 33 600 0.25 0.1 18 +0.088 81C CMPZ5253B 23.75 25 26.25 5.0 35 600 0.25 0.1 19 +0.089 81D CMPZ5254B 25.65 27 28.35 4.6 41 600 0.25 0.1 21 +0.090 81E CMPZ5255B 26.60 28 29.40 4.5 44 600 0.25 0.1 21 +0.091 81F CMPZ5256B 28.50 30 31.50 4.2 49 600 0.25 0.1 23 +0.091 81G CMPZ5257B 31.35 33 34.65 3.8 58 700 0.25 0.1 25 +0.092 81H CMPZ5258B 34.20 36 37.80 3.4 70 700 0.25 0.1 27 +0.093 81J CMPZ5259B 37.05 39 40.95 3.2 80 800 0.25 0.1 30 +0.094 81K CMPZ5260B 40.85 43 45.15 3.0 93 900 0.25 0.1 33 +0.095 81L CMPZ5261B 44.65 47 49.35 2.7 105 1000 0.25 0.1 36 +0.095 81M CMPZ5262B 48.45 51 53.55 2.5 125 1100 0.25 0.1 39 +0.096 81N CMPZ5263B 53.20 56 58.80 2.2 150 1300 0.25 0.1 43 +0.096 81P CMPZ5264B 57.00 60 63.00 2.1 170 1400 0.25 0.1 46 +0.097 81Q CMPZ5265B 58.90 62 65.10 2.0 185 1400 0.25 0.1 47 +0.097 81R CMPZ5266B 64.60 68 71.40 1.8 230 1600 0.25 0.1 52 +0.097 81S CMPZ5267B 71.25 75 78.75 1.7 270 1700 0.25 0.1 56 +0.098 81T
SOT-23 CASE - MECHANICAL OUTLINE LEAD CODE:
1) Anode 2) No Connection 3) Cathode R10 (3-February 2010)
w w w. c e n t r a l s e m i . c o m
