Datasheet BAT46 (STMicroelectronics) - 5
DescriptionSmall signal Schottky diodes
Pages / Page11 / 5 — BAT46 Series. Ordering information scheme. BAT46 xx xx FILM. Signal …
File Format / SizePDF / 158 Kb
BAT46 Series. Ordering information scheme. BAT46 xx xx FILM. Signal Schottky diodes. Configuration. Package
BAT46 Series Ordering information scheme BAT46 xx xx FILM Signal Schottky diodes Configuration Package
BAT46 Series Ordering information scheme 2 Ordering information scheme BAT46 xx xx FILM Signal Schottky diodes Configuration
No letter = Single diode A = Common anode C = Common cathode S = Series diodes
Package
Blank = SOT-23 J = SOD-323 W = SOT-323 Z = SOD-123
Package
FILM = Tape and reel 5/11 Document Outline BAT46 Series Small signal Schottky diodes 1 Characteristics Table 1. Absolute ratings (limiting values at Tj = 25˚ C, unless otherwise specified) Table 2. Thermal parameters Table 3. Static electrical characteristics Table 4. Dynamic characteristics Figure 1. Average forward power dissipation versus average forward current Figure 2. Average forward current versus ambient temperature (d = 1) Figure 3. Reverse leakage current versus reverse applied voltage (typical values) Figure 4. Reverse leakage current versus junction temperature Figure 5. Junction capacitance versus reverse applied voltage (typical values) Figure 6. Forward voltage drop versus forward current (typical values, low-level) Figure 7. Forward voltage drop versus forward current (typical values, high-level) Figure 8. Relative variation of thermal impedance junction to ambient versus pulse duration - printed circuit board, epoxy FR4 eCU = 35 µm (SOD-323) Figure 9. Relative variation of thermal impedance junction to ambient versus pulse duration - aluminium oxide substrate 10 mm x 8 mm x 0.5 mm (SOT-23) Figure 10. Variation of thermal impedance junction to ambient versus pulse duration - printed circuit board, epoxy FR4, eCU = 35 µm (SOT-323) Figure 11. Thermal resistance junction to ambient versus copper surface under each lead, epoxy FR4, eCU = 35 µm (SOD-323) 2 Ordering information scheme 3 Package information Table 5. SOD-123 dimensions Figure 12. SOD-123 footprint (dimensions in mm) Table 6. SOD-323 dimensions Figure 13. SOD-323 footprint (dimensions in mm) Table 7. SOT-23 dimensions Figure 14. SOT-23 footprint (dimensions in mm) Table 8. SOT-323 dimensions Figure 15. SOT-323 footprint (dimensions in mm) 4 Ordering information 5 Revision history
