Datasheet TLP624, TLP624-2, TLP624-4 (Toshiba)
Manufacturer | Toshiba |
Description | TOSHIBA Photocoupler IRED & Photo-Transistor |
Pages / Page | 9 / 1 — TLP624, TLP624-2, TLP624-4. Option(D4) |
File Format / Size | PDF / 370 Kb |
TLP624,TLP624-2,TLP624-4 TOSHIBA Photocoupler IRED & Photo-Transistor
Programmable Controllers Unit: mm AC/DC-Input Module Telecommunication The TOSHIBA TLP624, -2 and -4 consist of an infrared emitting diode optically coupled to a photo-transistor. The TLP624-2 offers two isolated channels in an eight lead plastic DIP, while the TLP624-4 provides four isolated channels in a sixteen plastic DIP. • Collector-emitter voltage: 55 V (min) • Isolation voltage: 5000 Vrms (min) • UL-recognized: UL 1577, File No.E67349 • cUL recognized: CSA Component Acceptance Service No.5A TOSHIBA 11-5B2 File No.E67349 Weight: 0.26 g (typ.) • VDE-approved: EN 60747-5-5 (Note 1) Unit: mm Note 1: When a VDE approved type is needed, please designate the
Option(D4)
. • Note: Application type name for certification test, please use standard product type name, i.e. TLP624(BV): TLP624 TLP624-2(BV): TLP624-2 TOSHIBA 11-10C4 Weight: 0.54 g (typ.) Unit: mm TOSHIBA 11-20A3 Weight: 1.1 g (typ.) Current Transfer Ratio(min) Marking Classification Ta = 25°C Ta=-25 to 75°C of IF=1mA IF=0.5mA IF=1mA classification VCE=0.5V VCE=1.5V VCE=0.5V Rank BV 200% 100% 100% BV Standard 100% 50% 50% BV, blank Start of commercial production 1986-04 © 2019 1 2019-06-24 Toshiba Electronic Devices & Storage Corporation
