Datasheet AEM00330 (E-peas)
ManufacturerE-peas
DescriptionHighly Versatile Buck-Boost Ambient Energy Manager with Source Voltage Level Configuration
Pages / Page30 / 1 — DATASHEET. AEM00330. Highly Versatile Buck-Boost Ambient Energy Manager …
File Format / SizePDF / 896 Kb
DATASHEET. AEM00330. Highly Versatile Buck-Boost Ambient Energy Manager with Source. Voltage Level Configuration. Feature
Datasheet AEM00330 E-peas
DATASHEET AEM00330 Highly Versatile Buck-Boost Ambient Energy Manager with Source Voltage Level Configuration Feature Description
Ultra-low power start-up The AEM00330 is an integrated energy management circuit - Cold start from 275 mV input voltage and 3 µW input power that extracts DC power from an ambient energy harvesting (typical) source to simultaneously supply an application and store Constant input voltage regulation energy in a storage element. The AEM00330 al ows to extend battery lifetime and ultimately eliminates the primary energy - Optimized for intermittent and pulse power storage element in a large range of applications. - Selectable operating input voltage from 140 mV to 4.5 V Two different storage elements can be connected: one for Adaptive and smart energy management storing energy and another one for coupling the load output - Switches automatical y between boost, buck-boost and voltage. At start-up, user can choose to charge the storage buck operation, to maximize energy transfer from its input element first or the load capacitor first. to the output - Automatical y selects between the source, storage element Thanks to its selectable operating input voltage, it is possible to set a voltage at which the AEM00330 operates. This voltage is - Automatical y select the output between the internal between 140 mV and 4.5 V. supply, the load and the storage element Load supply voltage With its unique cold start circuit, the AEM00330 can start harvesting with an input voltage as low as 275 mV and from an - Current drive capability: 30 mA in low power mode, 60 mA input power of 3 μW. The preset protection levels determine in high power mode the storage element voltages protection thresholds to avoid - Selectable load voltage from 1.2 V to 3.3 V over-charging and over-discharging the storage element and Battery protection features thus avoiding damaging it. Those are set through configuration - Selectable over-charge and over-discharge protection for pins. Moreover, special modes can be obtained at the expense any type of rechargeable battery or (super-)capacitor of a few configuration resistors. - Fast super-capacitor charging The load voltage can be selected to cover most application - Dual cel super-capacitor balancing circuit needs, with a maximum available load current of 60 mA. Smal est footprint, smal est BOM - Only four external components are required - One 10 µH inductor
Applications
- Three capacitors: one 10 µF, one 15 µF, one at least 47 µF • Door access systems • Smart wearable sensors • Smart switches home/building • Point-of-sales (POS) CSRC LDCDC
Device Information
15uF 10uH Part Number Package Body size [mm] N T RC S LI U F 10AEM00330J0000 QFN 40-pin 5x5mm LO VINT BU SOURCE SRC VINT CINT AEM00330 10uF
Evaluation Board
VSTO STO LOAD LOAD CLOAD Part Number GND Storage 47uF Element 2AAEM00330J001 DS_AEM00330_Rev1.0 Copyright © 2022 e-peas SA 1 Document Outline Table of Contents List of Tables 1. Introduction 2. Absolute Maximum Ratings 3. Thermal Resistance 4. Typical Electrical Characteristics at 25 °C 5. Recommended Operation Conditions 6. Functional Block Diagram 7. Theory of Operation 7.1. DCDC Converter 7.2. Reset, Wake Up and Start States 7.2.1. Storage Element Priority Supercapacitor as a Storage Element Battery as a Storage Element 7.2.2. Load Priority 7.3. Supply State 7.4. Shutdown State 7.5. Sleep State 7.6. Source Voltage Regulation 7.7. Balancing for Dual-Cell Supercapacitor 8. System Configuration 8.1. High Power / Low Power Mode 8.2. Storage Element Configuration 8.3. Load Configuration 8.4. Custom Mode Configuration 8.5. Disable Storage Element Charging 8.6. Source Level Configuration 8.7. External Components 8.7.1. Storage element information 8.7.2. External inductor information 8.7.3. External capacitors information CSRC CINT CLOAD 9. Typical Application Circuits 9.1. Example Circuit 1 9.2. Example Circuit 2 9.3. Circuit Behaviour 9.4. DCDC Conversion Efficiency From SRC to STO in Low Power Mode 9.4. DCDC Conversion Efficiency From SRC to STO in Low Power Mode 9.5. DCDC Conversion Efficiency From SRC to STO in High Power Mode 9.6. DCDC Conversion Efficiency From STO to LOAD in Low Power Mode 9.7. DCDC Conversion Efficiency From STO to LOAD in High Power Mode 10. Schematic 11. Layout 12. Package Information 12.1. Plastic Quad Flatpack No-Lead (QFN 40-pin 5x5mm) 12.2. Board Layout 13. Revision History
