Datasheet CMHZ4678 - CMHZ4717 (Central Semiconductor) - 2
Manufacturer | Central Semiconductor |
Description | SURFACE MOUNT SILICON LOW LEVEL ZENER DIODES 500mW, 1.8 - 43 VOLT 5% TOLERANCE |
Pages / Page | 6 / 2 — CMHZ4678 THRU CMHZ4717. SURFACE MOUNT SILICON. LOW LEVEL ZENER DIODES. … |
File Format / Size | PDF / 786 Kb |
CMHZ4678 THRU CMHZ4717. SURFACE MOUNT SILICON. LOW LEVEL ZENER DIODES. 500mW, 1.8 THRU 43 VOLT. 5% TOLERANCE
CMHZ4678 THRU CMHZ4717 SURFACE MOUNT SILICON LOW LEVEL ZENER DIODES 500mW, 1.8 THRU 43 VOLT 5% TOLERANCE ELECTRICAL CHARACTERISTICS - Continued:
(TA=25°C), VF=1.5V MAX @ IF=100mA (for all types)
TEST MAXIMUM MAXIMUM MAXIMUM ZENER VOLTAGE CURRENT REVERSE ZENER NOISE MARKING TYPE CURRENT CURRENT DENSITY CODE VZ @ IZT IZT IR @ VR IZM ND @ IZT MIN NOM MAX μA μA V mA μV/ Hz V V V
CMHZ4697 9.500 10 10.50 50 1.0 7.6 24.8 40 CDE CMHZ4698 10.45 11 11.55 50 0.05 8.4 21.6 40 CDF CMHZ4699 11.40 12 12.60 50 0.05 9.1 20.4 40 CDH CMHZ4700 12.35 13 13.65 50 0.05 9.8 19.0 40 CDJ CMHZ4701 13.30 14 14.70 50 0.05 10.6 17.5 40 CDK CMHZ4702 14.25 15 15.75 50 0.05 11.4 16.3 40 CDM CMHZ4703 15.20 16 16.80 50 0.05 12.1 15.4 40 CDN CMHZ4704 16.15 17 17.85 50 0.05 12.9 14.5 40 CDP CMHZ4705 17.10 18 18.90 50 0.05 13.6 13.2 40 CDT CMHZ4706 18.05 19 19.95 50 0.05 14.4 12.5 40 CDU CMHZ4707 19.00 20 21.00 50 0.01 15.2 11.9 40 CDV CMHZ4708 20.90 22 23.10 50 0.01 16.7 10.8 40 CDA CMHZ4709 22.80 24 25.20 50 0.01 18.2 9.9 40 CDZ CMHZ4710 23.75 25 26.25 50 0.01 19.0 9.5 40 CDY CMHZ4711 25.65 27 28.35 50 0.01 20.4 8.8 40 CEA CMHZ4712 26.60 28 29.40 50 0.01 21.2 8.5 40 CEC CMHZ4713 28.50 30 31.50 50 0.01 22.8 7.9 40 CED CMHZ4714 31.35 33 34.65 50 0.01 25.0 7.2 40 CEE CMHZ4715 34.20 36 37.80 50 0.01 27.3 6.6 40 CEF CMHZ4716 37.05 39 40.95 50 0.01 29.6 6.1 40 CEH CMHZ4717 40.85 43 45.15 50 0.01 32.6 5.5 40 CEJ
SOD-123 CASE - MECHANICAL OUTLINE Lead Code:
1) Cathode 2) Anode R7 (23-September 2015)
w w w. c e n t r a l s e m i . c o m
